Old 22nd Feb 2018, 12:24 pm   #1
David Simpson
Default AVO 2 Panel Valve Tester
Along with the Tottenham WS Wavemeter, I've also been given this 2 Panel Tester in a heavy duty wooden box. It has "ADM PATT 55046 VALVE TESTER" on a wee outside label. The wood is painted an Army green colour. I'm not needing any info on 2 Panels, just wondering what the ADM PATT 55046 stands for. It also has a Crows Foot at the bottom R/H corner of the meter dial. Possibly "Admiralty Pattern". It has all the accoutrements with it.
Just need to know before I get rid of it along with the other surplus test equipment I was given last weekend.
Regards, David
Name:	2 Panel (a).jpg
ID:	157986   Click image for larger version
Name:	2 Panel (b).jpg
ID:	157987   Click image for larger version
Name:	2 Panel (c).jpg
David Simpson is offline
Old 22nd Feb 2018, 12:31 pm   #2
Default Re: AVO 2 Panel Valve Tester
Admiralty Pattern 55046.
Old 23rd Feb 2018, 12:38 am   #3
David Simpson
Thanks Lawrence for the confirmation. Did these boxed Naval versions differ in any way internally from the original civilian ones ? I had a civ one about 10 years ago, and this thing looks much the same.
Regards, David
Old 23rd Feb 2018, 7:56 am   #4
Kevin Hoyland
Morning David.
The only difference is the red light at the right hand side of the meter. The Wayn Kerr tester is still going good.
We have a good frost in Rotherham this morning.
Kevin
Kevin Hoyland is offline
Old 23rd Feb 2018, 10:56 am   #5
Craig Sawyers
Craig Sawyers's Avatar
Looks like really nice condition, with socket adaptors for later sockets. Should get good money for it wherever you dispose of it.
Craig Sawyers is offline
Old 26th Feb 2018, 4:38 pm   #6
avocollector
I have the exact same tester in the same green painted box!! who would have thought they would have made it out to NZ. Bought it years ago in a junk shop in town for $20 (about 10 quid).
avocollector is offline
Old 26th Feb 2018, 5:01 pm   #7
Craig Sawyers
And that was a bolted on bargain! Well probably par for the course depending on how long ago it was - but a bargain nowadays for sure.
Old 27th Feb 2018, 2:05 pm   #8
avocollector
Forgot to mention the box is liberally doused in oil inside and outside - I suspect linseed or similar to prevent rust from the saline conditions on board ship.
