Old 20th Oct 2019, 11:47 am   #1
hellensc
Default Ferrograph 4S Tape Recorder
Ferrograph 4S Fast forward and rewind working perfectly. Play not working. Any suggestions would be much appreciated.
hellensc is offline
Old 20th Oct 2019, 11:55 am   #2
Default Re: Ferrograph 4s Tape Recorder
When you say "Play not working" do you mean the reels don't rotate, or do they rotate but there's no sound?
Station X is online now
Old 20th Oct 2019, 12:03 pm   #3
hellensc
Hi Graham,
The wheels are not rotating.
Many thanks
Chris
hellensc is offline
Old 20th Oct 2019, 2:06 pm   #4
TIMTAPE
Default Re: Ferrograph 4S Tape Recorder
Does the capstan shaft rotate? Dos the capstan motor shaft rotate?
TIMTAPE is offline
Old 20th Oct 2019, 3:07 pm   #5
Ted Kendall
Are the speed and equalisation controls in agreement? Some Ferros refuse to play unless they are set to the same speed.
Ted Kendall is online now
Old 20th Oct 2019, 6:34 pm   #6
llama
llama's Avatar
Does the actuate (as one might call it) lever stay locked in place?
Graham
llama is offline
Old 21st Oct 2019, 9:50 am   #7
BillDWVA
I would suggest that if the motors are energising when in ‘FF’ or ‘REW’ but not in ‘PLAY’ then the first place to look would be the switch wafers in the main multi-function switch.
However...
Is the capstan rotating when in ‘FF’ or ‘REW’? If not then it may be a problem only with the capstan motor.
Bill
BillDWVA is offline
Old 22nd Oct 2019, 11:52 am   #8
Uncle Bulgaria
Uncle Bulgaria's Avatar
With my Ferrograph, I tried checking continuity (with the power off!) first of all with the switches in different positions, checking that the right circuits were being made and broken. It's always the simple things...
Uncle Bulgaria is offline
Old 22nd Oct 2019, 4:23 pm   #9
TIMTAPE
When I first inspected a Ferro 5 with the view to purchasing it, the owner showed me how he got the capstan motor to turn after engaging play. He lifted up the deck plate, gave the motor fan a spin and it sprang into life. I bought the machine and the first thing I did when I got it home was oil top and bottom motor bearings. From that time on, the motor never missed a beat.
TIMTAPE is offline
Old 22nd Oct 2019, 11:04 pm   #10
BillDWVA
A sluggish capstan motor is sometimes a symptom of a failing phase-shift capacitor.
Bill
BillDWVA is offline
Old 23rd Oct 2019, 10:10 am   #11
TIMTAPE
Bill
Absolutely!
TIMTAPE is offline
