8th Apr 2020, 10:25 am | #1 |
Garrard 4HF Problems
Can anyone help
I'm having problems with my Garrard 4HF For some reason the variable speed control won't work Sharon |
8th Apr 2020, 11:06 am | #2 |
Re: Garrard 4HF Problems
That's a chunky rheostat, as I recall. Is it not turning at all or moving but not affecting speed?
8th Apr 2020, 11:08 am | #3 |
Hi
It's turning ok but nothing happens, sometimes it works when it feels like it |
8th Apr 2020, 3:58 pm | #4 |
I've had one where it breaks up and the wires inside go all over the place, if the deck isn't earthed, you cold get a shock.
8th Apr 2020, 7:48 pm | #5 |
Could just be an intermittent connection to the rheostat. Best to remove the cage and check the wiring.
9th Apr 2020, 3:18 pm | #6 |
I hadn't used it for about 5 years
9th Apr 2020, 4:13 pm | #7 |
Have you tried a contact cleaner on the Rheostat slider and the windings that it touches?
Edward. |
9th Apr 2020, 5:08 pm | #8 |
If the rheostat fails to work properly after the actions suggested here, it could be replaced with a high wattage potentiometer. There is a thread on VE where this has been done successfully. The RC88 also has an identical rheostat.
Regards,
Anwesh |
10th Apr 2020, 12:18 am | #9 |
10th Apr 2020, 10:09 am | #10 |
Thanks very much everyone, I will try those suggestions
