6th Apr 2020, 1:58 pm | #1 |
HMV 2312 / Garrard 3000 repair
I recently got a HMV 2312 stereogram that I am restoring. It has a Garrard turntable inside it (I reckon it’s a 3000 although it doesn’t have the model number on it). I’ve restored it and the turntable works and the arm drops and returns automatically. However, when I stack records on the automatic spindle and select ‘auto’, the bottom record drops fine but the other records lay tilted on the spindle. They are tilted and block the arm from dropping to the record. If I stop the arm from knocking into them, the auto spindle eventually straightens them up. Basically, I think the auto spindle release mechanism is slower than the auto arm and I need it to drop the bottom record and straighten the others up before the arm tries to drop onto the record playing. Any help at all would be appreciated. I’m also planning to wire in new speakers if anyone has any suggestions of good models that would work. Again, any help on the automatic spindle mechanism would be hugely helpful! Thanks! |
6th Apr 2020, 2:19 pm | #2 |
Re: HMV 2312 / Garrard 3000 repair
Forgive me if I'm being thick, but isn't there an overarm to keep the record stack at 90 degrees to the spindle?
6th Apr 2020, 2:35 pm | #3 |
A photo of the deck will help.
6th Apr 2020, 8:14 pm | #4 | |
BTW The specifed Autochanger for this model is a Garrard 3000.
Edward. |
7th Apr 2020, 3:09 pm | #5 | |
Hi. I’ve attached a photo of the deck empty and then one of it when a record has dropped and the record stacked is tilted. You can see that it tilts down towards the arm and so gets in the way. |
7th Apr 2020, 3:15 pm | #6 | |
7th Apr 2020, 5:02 pm | #7 |
ok Can you post a picture of the auto spindle sideways on from the front with no records on it
7th Apr 2020, 5:18 pm | #8 |
I think the over arm should be nearer to the spindle. As it stands it's bound to tilt the stack.
7th Apr 2020, 5:33 pm | #9 | ||
Edward. |
7th Apr 2020, 5:57 pm | #10 |
Here’s a picture of it side on.
7th Apr 2020, 5:58 pm | #11 |
7th Apr 2020, 6:23 pm | #12 |
I agree.
The over arm might have been forced to the right against the will of the pin on its shaft, that would mean the angle between the over arm and the pin would be out. Lawrence. |
7th Apr 2020, 6:27 pm | #13 |
The overarm is either bent, or is not going down far enough to rest on the stack of records. With no records on the turntable, put the overarm in the centre position, make sure it is fully down, then measure the distance from the turntable at various points along the length of the overarm. It should lie at a dead 90 degrees to the centre spindle.
7th Apr 2020, 7:10 pm | #14 |
I concur with Audio1950 that the overarm may be bent.
Do not fit modern speakers to a unit of this age, they tend to be inefficient compared to older units |
7th Apr 2020, 7:20 pm | #15 | |||
7th Apr 2020, 7:42 pm | #16 | |
7th Apr 2020, 8:01 pm | #17 |
Hi Lawrence. This is what I reckon has happened. Is there any strategic way to fix it?
7th Apr 2020, 8:30 pm | #18 |
The spindle looks like it is in the wrong position. The part of the spindle where the mech parts stick out needs to be at the seven o clock position, however the clip that holds the platter on and also locks the spindle in position is missing.
7th Apr 2020, 9:42 pm | #19 |
A picture from a similar item on eBay shows the over arm much closer to the spindle. The OP will need to check what's been bent.
https://www.ebay.co.uk/sch/i.html?_f...84879&_sacat=0
7th Apr 2020, 9:45 pm | #20 | |
Ditto again with Graham.
There might have been a post with the same problem on here not too long ago with a method......anyone? Other's might have other observations, but apart from the orientation of the center spindle and the missing clip mentioned by BRASSBITS the way it looks to me in the photo is that the arm isn't over far enough....unless the photo is deceiving my eyes, which is always a possibility....having said that there are several photo's on the web including that of a manual that show the over arm further over to the center than the OP's is. Lawrence. |
