7th Apr 2020, 9:30 am | #1 |
Mystery amplifier
A curious rig has landed on a mate's bench. A passive control unit, a two valve preamplifier on a separate chassis, a power pack with an EZ91 and a power amplifier with two 807s, a slew of 2N3055s and no obvious power supply components. This is from an estate, obviously home brew and supposedly worked once. Said mate is, not unreasonably, looking for some circuit information, but he and I have neer seen anything like this! Does it ring a bell anywhere?
7th Apr 2020, 10:09 am | #2 |
Re: Mystery amplifier
Curious indeed. I'm probably completely wrong, but I would have thought that an EZ91 would be too puny to supply a pair of 807s? Or have I misunderstood and the EZ91 is in the pre-amp? Sorry, the coffee hasn't kicked in yet. Cheers, Pete.
7th Apr 2020, 10:30 am | #3 |
Perhaps there is another unit missing?
I think I'd find the speaker output terminals and trace things out backwards, at least the speaker outputs ought to be reasonably overt and unambiguous. Could the 807s be driving the 2N3055s or are the 2N3055s be constant current sources scattered all over the place. Anything is possible. Don't think you'd need 2N3055 to drive 807s. I'm going to watch this one unfold! David
7th Apr 2020, 10:47 am | #4 |
7th Apr 2020, 1:18 pm | #5 |
Could it be a modulator for an AM transmitter?
7th Apr 2020, 2:10 pm | #6 |
No - it was allegedly used to drive the speakers which came with it...
7th Apr 2020, 11:15 pm | #7 |
Could be a false allegation......
8th Apr 2020, 7:40 am | #8 |
Good point Chris, 1st rule of repair 101, " treat with large dose of salt anything customer tells you".
A few pics would help, not much to go on, the 3055's could be used as regulator's for htr supplies or floating/elevated as part of a pre-amp, 300v g2 regulation, or part of dynamic bias. The EZ91 might be there as part of a slow start circuit , all speculation though. Andy.
8th Apr 2020, 8:09 am | #9 |
I have let my imagination run wild on this one!
How about the 807's are being used as controlled rectifiers/regulators straight off the mains, the EZ91 just supplying power to the controller electronics. The 3055s are then used as conventional transistor amplifier. If any of this is the case its going to be a live chassis design. Yes I am getting cabin fever Cheers Mike T
8th Apr 2020, 8:52 am | #10 |
Passive preamplifiers and then valve buffers and hybrid silicon/thermionic amplifiers starts to seem a bit boutique-y to me. The 807 and the 2N3055 eras didn't overlap, so seeing both in one thing seems unnatural.
Come on, Ted, let's see some pictures! David
8th Apr 2020, 9:13 am | #11 |
I've asked - the beast is miles away and not in my care. Agreed, it's utterly boutiquey, though, if not plain daft...
8th Apr 2020, 3:47 pm | #12 |
Can your friend supply some pictures?
8th Apr 2020, 3:59 pm | #13 |
Sounds like it ought to be entertaining.
I guess I've got to stop thinking of the reproduction of sound and see a wild amplifier as an art-form in itself. The difficult bit is stopping myself giggling. David
8th Apr 2020, 5:04 pm | #14 |
It could be that its a transistor amp with a couple of 807's and a EZ91 for decoration.
