Old 31st May 2009, 9:50 am   #21
Station X
Station X's Avatar
Default Re: Marconiphone T69 Da - no reception
Looking at the bottom or wiring side of a valveholder the pins number clockwise from the gap or spigot. Readings are taken between the chassis and the pin.
Do you mean resistor colour code rather than capacitor? When giving measurements you need to quote units or they're useless. The colour code you quote is for a 47K (47000) ohm resistor.
Graham. Forum Moderator
Station X is offline
Old 31st May 2009, 10:00 am   #22
Steve_P
Steve_P's Avatar
For the VHF, try another UCC85.
Check the voltages on the UCH81 like Station X says above. Capacitors round the oscillator stage at a guess for LW.
Cheers,
Steve P.
Steve_P is online now
Old 31st May 2009, 1:14 pm   #23
benjamin77
benjamin77's Avatar
A success ...well nearly, it's now working on VHF and MW so just LW to tackle !
benjamin77 is offline
Old 31st May 2009, 1:29 pm   #24
Steve_P
Steve_P's Avatar
Measure the volts on the valve on MW and LW and get back to us.
Also, with the set off, switch to MW and go between Earth and pin 4 of the front of the wavechange switch. Just to prove L9 is OK.
Cheers,
Steve P.
Old 31st May 2009, 5:51 pm   #25
benjamin77
benjamin77's Avatar
Ok have now taken some reading from valve 2 ....correctly I hope.
Lw Mw
Pin 1 10v 5v
pin 2 64v 70v
pin 3 6v 5v
pin 4 127v 127v
pin 5 0v 0v
pin 6 0v 0v
pin 7 0v 0v
pin 8 0v 0v
pin 9 54v 54v
I am assuming that L9 is ok as when I test its contuniaty with a MM it bleeps.....
Old 31st May 2009, 6:23 pm   #26
Steve_P
Steve_P's Avatar
Well, the pin numbering is wrong, but that can be corrected...
Pin MW LW
1 54V 54V (Screen Grid of Mixer)
2 0V 0V (Grid 1 of Mixer)
3 0V 0V (Cathode)
4 + 5 Heaters
6 127V 127V (Anode of Mixer)
7 6V 5V (Grid 3 of Mixer)
8 64V 70V (Anode of Oscillator)
9 10V 5V (Grid of Oscillator)
If someone could prove I have done my correcting correctly I would be pleased.
L9 Looks OK to me.
Right - Next test. Radio on and turn it to 1500m / 200kHz : Radio 4. It used to be the light programme in days of old.
Get a portable set and put it close to the UCH81 and tune it to Radio 5 live at 433 Metres (693 kHz) and rock the tuning about on the Marconiphone set. You should hear the portable go quiet or whistle at some point. If you do, then the problem is on the aerial side of the set. If not, it's probably the oscillator stage.
Try a UCH81 (You never know) and then I would check caps in this area. Give the wavechange switch another clean. If you haven't done so already, change capacitor C34. C21 and check the wiring to the antenna coil and the coil itself.
Cheers,
Steve P.
Old 31st May 2009, 8:15 pm   #27
Dave Moll
Dave Moll's Avatar
In that case, you are saying that pins 4 & 5 (heaters) are both at 0v, which implies that the heater supply is not getting through
Dave Moll is online now
Old 31st May 2009, 8:21 pm   #28
Steve_P
Steve_P's Avatar
Well, the heaters are at AC aren't they. It's 100mA and 19v heater. It might show zero it depends on his meter, but measuring AC on a DC meter would give close to zero.
Let's see what he comes back with.
Cheers,
Steve P.
Old 31st May 2009, 8:27 pm   #29
Dave Moll
Dave Moll's Avatar
Ah yes, temporarily forgot that the average amplitude of a sine wave is zero
Old 31st May 2009, 9:02 pm   #30
benjamin77
benjamin77's Avatar
Swapped out the valve for another that I thought was wasnt working in an Ekco set that I have and there is no change . So my next step would be to change the caps you suggest but although I can see them on the wiring diagram I am struggling to locate them on the pcb.
I have also checked the wiring to the antenna coil and it is un broken and looks ok.
Thanks for your patience.
Ben
Old 31st May 2009, 9:06 pm   #31
Steve_P
Steve_P's Avatar
No worries. It's what we are here for.
Get a valve from a set that works (or a new one!) and try that. No luck with the other radio test?
Anyway, check all the individual bits on the board, and if it's on a circuit board, do all the joints anyway. A dry joint somewhere perhaps?
Good luck...
Cheers,
Steve P.
Old 31st May 2009, 9:50 pm   #32
Station X
Station X's Avatar
Your pin numbering looks fine to me Steve. Makes me wonder where I went wrong in describing pin numbering. I've taken the liberty of editing in the electrode names.
Old 31st May 2009, 10:27 pm   #33
benjamin77
benjamin77's Avatar
Ok its getting late so I will make this the last one of the day...
Tried the second radio test, as I tuned in the Marconiphone set the portable whistled through its speaker as though I was tuning it in...!
I guess this means that the oscillator section is working ... I think I will go back to the wave change switch and give it another going over, wave change switches seem to be the root of all evil !
If that dont work well what next ?
Old 31st May 2009, 10:43 pm   #34
benjamin77
benjamin77's Avatar
Sorry Graham..It would maybe seem that I read the pin numbers from the top of the pcb not below as you had described
Old 31st May 2009, 11:03 pm   #35
Steve_P
Steve_P's Avatar
What next - C21, R11, C22. Put an aerial onto Pin 2 (Grid) of V2 and see what happens then.
Cheers,
Steve P.
Old 1st Jun 2009, 10:30 am   #36
benjamin77
benjamin77's Avatar
I connected a makeshift arial to Pin 2 on V2 but no change...
Can some one confirm my suspicions......To locate the correct resistor (R11) on the PCB I would be looking for one colour coded brown,black,yellow giving 100 kohms as stated on the wiring diagram. C22 looks like it is connected directly accross the wave change switch and R11 is connected to the tuning block ?
I am probably wrong but hey I dont know If I dont ask...
Old 1st Jun 2009, 11:02 am   #37
Station X
Station X's Avatar
I always think of the colour code like this:-
First band is first digit
Second band is second digit.
Third band is number of zeroes dollowing first two digits.
So Brown, Black, Yellow is 10 0000 ohms or 100K ohms.
Old 1st Jun 2009, 11:09 am   #38
AlanBeckett
There is of course a mnemonic to help remember the colours, but in these PC days .......
AlanBeckett is offline
Old 1st Jun 2009, 11:47 am   #39
Station X
Station X's Avatar
I still use the non PC version because I learned it about 50 years ago and it's far too embedded in my brain for me to change.
PC versions are:-
Bad Beer Rots Our Young Guts But Vodka Goes Well
and
Bye Bye Rosie, Off You Go, Bristol Via Great Western
We'd better stay on topic though or I'll have to give myself another infraction.
Old 2nd Jun 2009, 6:54 pm   #40
benjamin77
benjamin77's Avatar
A Success...! Replaced R11 and C22 also popped in a new UCH81 and hey presto its working well on all bands. Surprisingly its got good volume and the reception to my ear is above expected considering this is a cheap set!
When I get the pictures downloaded I will post them on here for scrutinisation !
Would like to say a big thank you to all that helped many thanks for your patience
Now just to sort out my 2 little ECKO's
