10th Dec 2018, 8:02 pm | #1 |
Bush DAC90A live wire?
Hi just need to know which wire input is LIVE.
Red or yellow/red? |
10th Dec 2018, 8:14 pm | #2 | |
Re: Bush DAC90A live wire?
Use a multimeter to trace the live wire, don’t guess, better still put the correct lead on the radio. If it’s not the mains lead, more information and photo may help.
Frank |
10th Dec 2018, 8:22 pm | #3 |
in the chassis back of the mains pins ? see photo
10th Dec 2018, 8:23 pm | #4 |
The DAC90A should have a reversible mains connector, so might be wise to mark its orientation if you plan on doing anything with the back cover off and dont want the chassis to be live
Kevin |
10th Dec 2018, 8:34 pm | #5 |
SET NOT CONNECTED TO MAINS SUPPLY.
Connect a meter on ohms range one lead to chassis the other to each wire in turn. The wire with the LOWEST resistance to earth should be connected to the NEUTRAL pin of the mains plug.
10th Dec 2018, 9:38 pm | #6 |
thanks ,
10th Dec 2018, 9:48 pm | #7 | |
[Always treat the chassis as live, irrespective of what the supply wiring is doing!] |
11th Dec 2018, 8:37 am | #8 |
One of the two DAC90As I have here has a red/yellow mains lead under the black jacket, so could they have left the factory like that?
(Are we talking the plug-in mains lead colours or just the under-chassis wiring colours?) SR Last edited by Stuart R; 11th Dec 2018 at 8:40 am. Reason: Afterthought... |
11th Dec 2018, 4:07 pm | #9 |
Under chassis according to post 3
11th Dec 2018, 4:29 pm | #10 |
sorted now , all working apart from 1 bulb holder .
have changed the speaker and bulb holder wires possibly bad connection between the layers ? |
