#1 |
I wonder if anyone knows the difference between the earlier Radiospares TH.1 and the later TH-1A please. I have their 1967 catalogue listing the TH.1 as equivalent to VA1015. Res cold 930 ohm, Res hot 42 ohm @ 0.3A. The only difference I can see is the TH.1 has what looks like end caps fitted whereas my TH-1A has wires wrapped around either end. Were these onlyith the 0.3A quoted, were these used in 0.3A heater chains on tv or also as ht inrush limiters as well? Reason I ask is I have some I found when sorting.
Thanks. Rob
I am also interested in and collect 00 model railway. |
#2 |
As a comparison with the suffix, the Brimar/STC CZ range that have the suffix A added are the same electrically, eg: CZ1 and CZ1A are electrically the same but in those the CZ1 is a wrapped wire connection and the CZ1A is an end cap and wire connection.
Lawrence. |
#3 |
Thanks Lawrence. Strange the " A" designation of wire and end caps between the 2 suppliers. Maybe RS ones were from STC.
Rob
#4 | |
![]() Quote:
https://www.rsp-italy.it/Electronics...20-%201958.pdf Lawrence. |
#5 |
Thanks Lawrence,
you are always a fountain of knowledge! Rob
