Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Websites
Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest.
Old 5th Apr 2021, 11:19 am   #1
chriswood1900
Default EEVBLOG gone offline.
In case you were wondering.
As of approximately 21:13:00 04-04-2021 UTC there was a major outage at the datacenter in Odgen Utah where the EEVBlog servers are hosted. This outage was caused by a fire as a result of performing regular load testing of the emergency generators.
Unfortunately due to the nature of the failure it may be some time before the EEVBlog website and forums are restored to normal operation. Thankfully we maintain several off-site backups of the entire EEVBlog infrastructure, as a result there is no need to worry about any loss of data.
Also please be aware that due to this dave@eevblog.com is also not available, if you need to contact Dave directly please use his alternative email address eevblog@gmail.com
It would appear there is a major problem with their methodology for testing, I have been involved in many tests of data-centres and have yet to set one on fire!!
Chris Wood
BVWS Member
chriswood1900 is offline   Reply With Quote
Old 6th Apr 2021, 5:52 am   #2
mole42uk
mole42uk's Avatar
Default Re: EEVBLOG gone offline.
It rather reminds me of an incident many years ago when a British telecommunications company were load-testing a generator that both powered the site and charged a substantial battery bank. The charger went awry and cooked a lot of new lead-acid gel cells. Someone wasn't happy.....
Richard
Index:
mole42uk is online now   Reply With Quote
Old 6th Apr 2021, 8:19 am   #3
dglcomp
I bet the supplier/manufacturer of said battery charger got an expensive phone call!
Just proves that you can test all you like but murphy will still get you.
dglcomp is offline   Reply With Quote
Old 6th Apr 2021, 1:35 pm   #4
Wellington
Wellington's Avatar
…and have yet to set one on fire!!
There was a fire in a data centre in Strasbourg, that I read about recently…
Wellington is offline   Reply With Quote
Old 6th Apr 2021, 5:20 pm   #5
chriswood1900
Updates: From Temp site.
2021-04-05 08:56:00 UTC - Current updates project that close to 90-95% of all hardware experienced zero damage. Electricians are working now to restore power to the Ogden Utah data center and are estimating power should return at approximately 3:00 pm MDT tomorrow.
Which by my reckoning is 10pm BST
Chris Wood
BVWS Member
Old 7th Apr 2021, 6:43 pm   #6
factory
Seems the story has changed, it now says the city power had gone out and the generators failed doing the job they were supposed to do (not a test).
Also seems to eevblog forum servers were in the worst affected area of the building and won't be running anytime soon.
2021-04-07 08:25:46 UTC - Informational update above, fire was not caused by genset test but rather genset use during a city wide power outage.
2021-04-07 08:40:00 UTC - GorillaServers have confirmed that our servers "were located in the section with a high probability of water damage. So they will need to be physically inspected before they can be powered on."
2021-04-07 18:21:21 UTC - A contact at GorillaServers has confirmed that it is almost certain that the two webservers will not be restored today in their current state and are looking at the possibility of issuing us a temporary server in the Los Angeles DC in the meantime
factory is offline   Reply With Quote
Old 7th Apr 2021, 9:15 pm   #7
GrimJosef
We had a small (i.e. not damaging to the building) fire at the place I used to work. The real post-fire problem was not the effects of heat but the fact that all the electronic equipment's ventilation fans had sucked the smoke in, which then coated the pcbs in something which needed to be laboriously cleaned off. Rescuing the equipment kept it out of use for weeks, and in some cases months.
GJ
http://www.ampregen.com
GrimJosef is online now   Reply With Quote
Old 7th Apr 2021, 10:06 pm   #8
Craig Sawyers
Craig Sawyers's Avatar
Another forum that I am on hosted somewhere in the US has been down for several days. Perhaps it is a casualty of the same power outage.
Craig
Craig Sawyers is offline   Reply With Quote
Old 8th Apr 2021, 2:17 am   #9
Today, I watched an EEVBlog on his newly acquired HM bench DMM. So he must have reorganised things?
Old 8th Apr 2021, 8:19 pm   #10
factory
I guess you haven't seen many recent videos, he's has moved back to the original office space that he actually owns, rather than paying rent for the larger office space he was using till some-point last year.
Anyway the eevblog forum seems to have returned.
