28th Jan 2008, 2:12 pm | #1 |
FRDX400 S Meter
I am currently restoring a Yaesu FRDX400 to it's former glory, but one thing is troubling me. Upon switching on the Rx, the S Meter bangs hard over at full scale for approx 15 seconds until the receiver starts to warm up.
Looking at the circuit (attached) I cannot see what is passing current in the anode circuit to cause this to happen. Does anyone have a FRDX400 and if so is this normal. Or can anyone explain what is happening ? D113 is not short circuit. Thanks John |
28th Jan 2008, 4:56 pm | #2 |
Re: FRDX400 S Meter
John I got one of these recently. Not much time to look at it but dead at present-could be major power supply problems [lets look on the bright side] so I can't light it up to observe the meters but it doesn't sound right! However, Graham [Station X] very kindly e-mailed me a copy of the manual in response to my general request and he did say that he had worked on one of these for a friend so that seems a good starting point.
I will be interested to see what info comes through. Cheers Dave |
28th Jan 2008, 9:00 pm | #3 |
Re: FRDX400 S Meter
Once you get time Dave, I'll be happy to give you any help with voltage / resistance readings if needed. (Apart from the S meter ) I picked mine up on the usual web auction site, it has all filters fitted, xtal calibrator, FM unit and 2m / 6m converters fitted. After a bit of TLC it seems to be working well HF wise except for the 10m and CB (who cares about that) ranges. May just be the calibrator signal is weaker at 28Megs, I'll have to put a sig gen on it. It was a delight to align apart from the said 10m range.
Have still to work on the 2m / 6m units, lots of noises from the 2m unit, but nothing intelligent. There appears to have been two versions of the FRDX circuitry wise, mine has a 2 transistor 9v regulator whereas one circuit diagram I looked at only uses a zener. John |
29th Jan 2008, 3:27 pm | #4 |
Re: FRDX400 S Meter
John,
Assuming V105 is an AGC controlled IF stage then an increase in anode voltage (caused by a reduction in anode current due to more negative AGC volts) will produce more meter deflection. The fact that the meter reads full scale implies that there is insufficient anode current to start with and that it takes a long time to get to its correct value. Could be a number of causes - possibly V105 is low emission. HTH
29th Jan 2008, 3:40 pm | #5 |
Re: FRDX400 S Meter
Clearly you know what you are talking about Keith. The Handbook
trouble shooting section refers the reader to the AVC circuit in the event of problems with the meter but you are a lot more detailed. Thanks to John for his offer-I've sent a pm. Dave |
29th Jan 2008, 9:19 pm | #6 | |
Re: FRDX400 S Meter
John |
30th Jan 2008, 12:02 am | #7 |
Re: FRDX400 S Meter
John,
I've just re-read your original post - somehow I'd got 15 minutes into my head rather than 15 seconds! An short initial overshoot is quite normal and, in fact, difficult to avoid in a valve receiver. My HRO does exactly the same, and must have been doing so for 65 years without any damage to the meter movement.
30th Jan 2008, 12:10 am | #8 |
Re: FRDX400 S Meter
From the circuit there is nothing to limit the meter moving hard over while the set stabilises from switch on. slightest voltage over R129 will cause some meter movement , you have an agc line feed on on side which will take time to stabilise. i can think of quite a few military valve comms sets that behave this way.
Mike |
30th Jan 2008, 1:24 pm | #9 | |
Re: FRDX400 S Meter
John |
30th Jan 2008, 1:53 pm | #10 |
Re: FRDX400 S Meter
John
As MichaelR says, the meter will go hard over until the DC conditions are stabilised. For example if the HT comes up first, before V105 is conducting, the full HT will be applied to one side of the meter via two series resistors and the diode and be compared with a potted down version of the HT on the other side of the meter. This will cause a deflection dependent on the current flowing. When the dc conditions do stabilise, the potential difference either side of the meter will be very small and the meter deflection will be correspondingly small, proportional to the pot settings. When radio signals are received, they will be rectified by the diode and smoothed by the filter capacitor and this dc voltage will cause a deflection proportional to signal strength. Are you able to try delaying the application of the HT until the valve heaters have warmed up? This might help the DC conditions to stabilise more quickly and put less strain on the meter movement. Ron Last edited by ronbryan; 30th Jan 2008 at 1:59 pm. |
30th Jan 2008, 2:13 pm | #11 |
Re: FRDX400 S Meter
John,
As Ron explains, you have to consider the circuit as a bridge. The potential difference is between what will be almost full HT (before the valve has started to conduct) and the lower voltage on the adjusment pot slider. It may be exacerbated by the use of solid state rectifiers in the power supply - an indirectly heated valve rectifier should give less of an problem due to the delay in HT. I think the diode is there just to protect against reverse deflection when the set is switched off - the meter is simply a way of indicating anode current variation in the IF amplifier due to AGC action.
30th Jan 2008, 2:30 pm | #12 |
Re: FRDX400 S Meter
Thanks Ron & Keith - you do have differing views on the function of the diode though. I like Ron's suggestion to delay the HT - there is a standby position on the main function switch which is linked to the monitor pot for monitoring your Tx signal - basically biases back the grids heavily, maybe I'll change that to feed a relay to open the HT feed as I don't have a Tx at present. (Don't want to add a new switch as this will spoil the original look)
Point taken about a bridge - but surely a bridge has a +ve and -ve connection ? This is my logic to the problem - where is the -ve connection here if you remove V105 ? John |
30th Jan 2008, 3:01 pm | #13 |
Re: FRDX400 S Meter
John
Keith is quite correct about the function of the diode. I overlooked the decoupling capacitor at the top of the tuned circuit, which will remove most of the RF. The -ve connection to the bridge is the potential divider formed by VR103 and R130. Ron |
30th Jan 2008, 3:08 pm | #14 |
Re: FRDX400 S Meter
I've just had an email from a mate who has an FRDX400. He confirms that the S Meter bangs the end stop on switch on then drops back.
So either this is normal operation or both sets have the same fault.
30th Jan 2008, 3:45 pm | #15 | |
Re: FRDX400 S Meter
A bridge measures a differnece in potential. if you look at the circuit carefully you will see there is voltage feed ( irrespective of the valve) through the coil and as I said AGC from the other side. I owned one of these sets 12 years ago |
30th Jan 2008, 5:15 pm | #16 |
Re: FRDX400 S Meter
31st Jan 2008, 11:33 am | #17 |
Re: FRDX400 S Meter
John,
Just to clarify I've attached a simplified circuit showing the bridge arrangement. HTH
31st Jan 2008, 1:49 pm | #18 | |
Re: FRDX400 S Meter
This is really the point I am trying to get over - or maybe I am just very dumb. John |
31st Jan 2008, 2:10 pm | #19 |
Re: FRDX400 S Meter
The resistor and pot connected between HT+ and ground have current flowing through them as a result of the HT voltage being across them. Whenever current flows through a resistor a voltage appears across it. The voltage is given by current times resistance. (IR).
This voltage is also across the S meter and the components in series with it. So the meter deflects. You might be able to understand more easily if you mentally remove all the components except the resistor, pot and meter.
31st Jan 2008, 2:33 pm | #20 | |
Re: FRDX400 S Meter
Station X is right in what he says , the bridge sees the volt drop (potential difference) across the resistor. mike |
