7th Jan 2008, 9:37 pm | #1 |
T1154 PA valves
A friend of mine has found six VT104s among a box of valves in his loft. These output valves were used in pairs in the PA stage of the famous T1154 RAF transmitter.
Would anyone relatively local in the Worcestershire/Birmingham/West Midlands area owning a valve tester capable of testing these beasts properly be able to test them for us please? My simple Weston TV-4A valve checker is a bit too basic for such potentially valuable/rare valves. All expenses reimbursed of course. Thanks, Phil
7th Jan 2008, 9:42 pm | #2 |
Re: T1154 PA valves
Phil,
I think you will struggle getting them tested on a valve tester, as there arent many that work at a kv on the anode..... Rare? not really, Valuable? erm, about 20 quid a piece. I have not found a bad one yet (about 20 currently in stock here) Best you could do is lash up a test rig and compare results to the valve data. Cheers Sean
7th Jan 2008, 11:00 pm | #3 |
Re: T1154 PA valves
Then can be teted on an AVO VCM - I've done them in the past, and they are listed in the AVO valve manual (under their civilian designation).
Jim. |
7th Jan 2008, 11:15 pm | #4 |
Re: T1154 PA valves
That would be PT15 then
7th Jan 2008, 11:26 pm | #5 |
Re: T1154 PA valves
Thanks Sean,
I couldn't remember the number. I tested mine with a AVO mk3, so any of that range should do, not sure about the CT160 though. I fairly sure that the 2 panel type tester won't handle them. Jim. |
8th Jan 2008, 12:29 am | #6 | |
Re: T1154 PA valves
Phil
