Old 11th Apr 2019, 7:57 pm   #1
collisr
collisr's Avatar
Default Power issue (?) on a Sony VO9600 u-matic
Hi all,
I wonder if anyone has seen this issue before. I have 2 of these machines - one works great - the other has a power issue.
The symptom is:
- on power on (switch at the front), the VU meters twitch, the front lights (SP/High band etc) flick on for a split second and then the unit goes dead. Buttons don't respond, no lights on - nothing.
- occasionally - usually after being left switched off for 5 mins or so - the unit DOES power-up successfully and stay on. If you power off and on-again, it goes back to the fault
So far, I have swapped over the AC-DC and DC-DC power boards (which are known to work okay on the good machine) and no-change!
Before I go any further, anyone seen this before? Given its not the power supply itself, is this some sort of safety shutdown/short-protection from elsewhere? Couldn't see this noted as a common fault so was hoping someone might have some pointers.
Rob
collisr is offline
Old 11th Apr 2019, 11:03 pm   #2
wave solder
wave solder's Avatar
Default Re: Power issue (?) on a Sony VO9600 u-matic
I had the mains power switch go intermittent on one of mine.
wave solder is offline
Old 12th Apr 2019, 1:47 pm   #3
collisr
collisr's Avatar
Thanks wave solder !
You were 100% on the money with my machine. "Servisol"-ed the front power switch and problem solved.
Fitted a replacement pinch roller (thanks whiskers), cleaned, oiled and greased and works a treat!
Thanks again
Rob
collisr is offline
