14th Oct 2014, 5:16 pm | #1 |
746 Bell Wiring?
Hello,
a while back I disconnected the bell inside my 741 wall phone by removing a blue wire (going to the right hand side of the bell clapper) as I was just using my bell set number 26 for my phone collection. This has changed and now when I have tried connecting it onto T14 the bell won't ring. Any idea why? Thanks Ryan |
14th Oct 2014, 6:03 pm | #2 |
Re: 746 Bell Wiring?
Ryan,
Please post a good, close-up picture of your PCB and its wiring. BTW, are you using a good quality microfilter, which will provide a ringing signal on the blue wire in the line cord? N. |
14th Oct 2014, 6:34 pm | #3 |
I've never had an issue with it before. It was disconnected about two or three weeks back as I was using my bell set No 26 for the main bell. Now since I have my PBX I want to connect it back to it.
I don't have a micro filter since it is connected into my Panasonic branch exchange. I will post a photo later though |
14th Oct 2014, 6:38 pm | #4 |
The bell coils should be between T4 and T16-19 (the four that are strapped together). You say you've connected it to T14 which is a spare.
- Joe |
14th Oct 2014, 6:48 pm | #5 |
I'm sure that's what It was connected to, since that is the only one on the PCB with a screw missing. I will have another look though.
Ryan |
14th Oct 2014, 6:57 pm | #6 |
Joe's right of course!
T14 has nothing connected under the PCB - have a look if you don't believe us. N. |
15th Oct 2014, 3:35 pm | #7 |
Joe was right ha ha, the screw must have dropped out. works fine mounted on T19.
