20th Jun 2020, 4:07 pm | #21 |
Re: Sony TC 800A portable R2R belts
20th Jun 2020, 4:27 pm | #22 | ||
20th Jun 2020, 4:36 pm | #23 |
This TC-800A seems to be specific to Japan 100 volts mains, according to its label as attached.
20th Jun 2020, 4:39 pm | #24 |
A very interesting machine that was available in 2, 3 and 4 speed versions. The 4 speed had a built in microphone.
UK versions were supplied to run on 117/240 volts approx selectable by an internal switch I believe. US versions would only run on 117V... why did the Japanese make multi-tap transformers for use worldwide but only fit 117V ones in the US? Being a linear power supply it will not take any old mains voltage without adjustment. It sounds like the OP’s machine is a US model since it appears to lack the Mains voltage adjustment. I don’t know if all versions use the same belts but I would imagine that they do since the speed change is achieved electronically. Sadly they use the novel but rare 4 pin mains/battery connector. Peter |
20th Jun 2020, 5:01 pm | #25 | |||
20th Jun 2020, 5:05 pm | #26 |
Yes David i see the voltage on your picture but as you can see on the photo of the information plate that posted earlier there is no mention of any ac voltage, very strange.
20th Jun 2020, 5:12 pm | #27 | |
The linear mains lead is extremely difficult to find. Thanks Trevor |
20th Jun 2020, 7:40 pm | #28 |
It could be that there are two windings one is 100V the other 120V. Put them in series and you get 230V
20th Jun 2020, 8:38 pm | #29 |
Here is the identification from the bottom of one of mine and the plate underneath the power connector. This is a 4 speed model with built in mike. Obviously the previous owner did not have the original and correct power connector and performed this bodge!
It certainly gives the impression that the mains voltage cannot be adjusted. I have yet to remove the bottom to check. Peter |
20th Jun 2020, 8:43 pm | #30 |
20th Jun 2020, 8:46 pm | #31 | |
Thanks Trevor |
20th Jun 2020, 9:44 pm | #32 |
When I had the same issue with a nice enough 117v Concord one of you folks gave me a timely reminder that the pulley wold be sized for 60hz and would need replacing, additional to the stepdown tfr. However, since this is a portable with a low voltage DC (?) function would its motor be AC or DC?
If you can live with an extra piece of kit plus its cabling it might be a not so neat solution, even if not permanently ? T |
20th Jun 2020, 11:27 pm | #33 |
The motor is a servo motor and is independent of the mains frequency.
20th Jun 2020, 11:58 pm | #34 | ||
It would help to clarify this ongoing confusing issue if you could check out exactly what the mains transformer primary wiring connections are and where they connect back to. Difficult from the photo to see all the connections clearly. Looks like a white wire on the 110 volt tap. Possibly a white wire on the 0V tap (there should be a connection to the 0V tap). Does not look like there is a connection on the 120 volt tap, but looks like there is another white wire there but cannot see if it connects to the transformer. Are there any other identified primary taps like 220/230/240 or another 0V tap ? David |
21st Jun 2020, 12:47 am | #35 |
There is a schematic for the TC-800 ( A or B suffix not referenced) on radiomuseum.org that shows 2 primary windings (as Michael suggested) and the various connections for the 4 voltage options, namely 110, 120, 220 & 240.
21st Jun 2020, 9:02 am | #36 |
Ok guys, this picture of the transformer, the top right 120 volt wire is also connected to the bottom left 110 terminal, the top left 110 volt wire is only to that one terminal and the bottom right 120 volt terminal is only wired to its 120 volt termainal. Is this any use ?
21st Jun 2020, 9:53 am | #37 |
It helps Trevor but I still find it a little confusing. I think it goes some way to proving that it is 240 wired as you thought it was, but not 100% conclusive yet.
Because the radiomuseum schematic is copyrighted I cannot attach a copy of it or the relevant section. It shows the 2 primary windings each have a centre tap, so there are 6 taps in total for the primary windings. I think yours has 6. The schematic is a little unhelpful in the fact that it does not name any of the taps. So the top left white shape that I thought may have been a white wire going to the 0V tap is not a wire but a plastic corner of the transformer. I now think that your top left white wire connects to the 0V tap, even though it looks like it is the 110V tap, I think the alignment of the tap identification lettering is not aligned correctly to the physical taps. So do you definitely only have 2 wires leaving the transformer primary, namely:- 1. Top left white wire that connects to 0V tap (but looks like 110V tap). 2. Top right white wire that connects to 120V tap. In addition to this wire and the white wire link that connects the top 120V tap to the bottom left 110V tap (probably actually the 0V tap, i.e. the furthest left tap) it looks like there may be another white wire connecting to the top 120V tap, is this correct ? There should be 3 wires leaving the transformer primary. Could you get a photo of the bottom taps with the cables below pulled back out of the way. Last edited by DMcMahon; 21st Jun 2020 at 10:00 am. |
21st Jun 2020, 10:27 am | #38 |
I would have thought there would have been a selector switch/panel, why else would there be a wire from the center tap going away from the transformer.
Lawrence. |
21st Jun 2020, 10:58 am | #39 |
From my view of the photo it is not clear if there is a connection to one of the centre taps, that is why I have asked for a better photo showing the bottom taps.
The schematic shows one of the centre taps connecting to the neon mains on indicator. David |
21st Jun 2020, 11:07 am | #40 |
I don't have a schematic to hand but the transformer looks like a universal job, so 240 volts is feasable, tag to the left looks like 0v.
Lawrence. |
