7th Jun 2020, 4:01 pm | #1 |
EL85 Valve. Usage?
Anybody any idea what set/sets used the EL85 valve? I've found a box of three new ones but can't think of what they were used for.
TimR
All those moments will be lost in time, like tears in rain. Last edited by flyingtech55; 7th Jun 2020 at 4:02 pm. Reason: Typo |
7th Jun 2020, 4:13 pm | #2 |
Re: El85
Not a commonly used valve but at least one set used it
https://www.radiomuseum.org/r/hismasters_1623.html I think it more often appeared in commercial equipment. Cheers Mike T
7th Jun 2020, 4:16 pm | #3 |
Re: El85
The valve museum entry gives some guidance about what Mullard expected it to be used for http://www.r-type.org/exhib/aaa0226.htm but whether it actually was used for this I don't know.
Cheers, GJ
http://www.ampregen.com |
7th Jun 2020, 4:54 pm | #4 |
Re: EL85 Valve. Usage?
Supposedly part of the long-running low heater power family that went EL2, EL32, EL42, EL95, ISTR that the difference between it and EL95 was that the 9-pin base meant that the suppressor grid and cathode connection could be separated, which suited it better for RF PA-type applications. Once the EL42 goes extinct, it could be a retro-fit candidate!
7th Jun 2020, 5:07 pm | #5 |
The 200mA heater made it handy to use with an EF86 for a low power audio amp for systems using 12 volt heater supplies such as vehicles and Leevers Rich tape machines.
10th Jun 2020, 9:54 pm | #6 |
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
It was used in the transmitter mutiplier stages of some early 1960's Hudson mobile two-way radios.
Ian |
11th Jun 2020, 2:27 pm | #7 |
I've also seen - in a military-airband transceiver - a pair of them in Class-A push-pull as modulator, with a QQV02/6 as the PA. Five watts of RF don't need much AF to give 100%+ "speech quality" modulation, and two EL85 take up less space/need less heater-power than something like a pair of 6V6.
11th Jun 2020, 8:54 pm | #8 |
Hi!
There are, in fact, enough pins on the B8A Rimlock.base to provide s separately pinned suppressor–grid connection (the EF40, EF42 and EAF42 diode/pentode all had separately pinned suppressor grids, so theoretically, you could make a single–ended power output valve with a separately pinned G3 for r.f. power amplifiers, but I don't think any valve–manufacturer actually did so! Chris Williams
12th Jun 2020, 10:34 am | #9 |
The EL43 and EL44 have seperate suppressor-grid connections.
https://frank.pocnet.net/short/054/2/218.pdf https://frank.pocnet.net/short/054/2/213.pdf |
12th Jun 2020, 11:38 am | #10 |
I was about to say that I had never seen an EL85 until Ian mentioned Hudson PMRs. I used to maintain a number of those in the '60s for the local garage's FX4 Taxi fleet - so I must of done, obviously never had to change one.
Peter |
12th Jun 2020, 12:20 pm | #11 |
I never replaced one in a Leevers Rich either - that`s why I have several NOS in the loft.
13th Jun 2020, 10:27 am | #12 |
I think the el85 was/is mainly a low power rf valve. there were two in the PYE
ptc 114 early pmr rig from the 50s I used the tx as my first 70MHz am rig it had an ef91 Xtal osc,two el85 as multiplier and driver to an 832 PA The modulator was two 6v6gt and a carbon mic, I added a pre-amp for a crystal mic. it's been scrapped long ago but I still have the Mod transformer built into another Transmitter.
HAPPINESS IS A WARM WIRELESS PREVIOUS USER NAME- MIKE G3ZII |
