17th Aug 2016, 12:11 pm | #1 |
IC polarity
I feel stupid asking, but I am struggling to get a fluorescent power meter to work on a amplifier.
Pin 1 is the one on the left? Pin 1 is the one marked on the board? I have power to the IC. Signal to the IC. However voltage at power pin is full VCC, 45v, its dropped via a 1.8K which is fine. It seems the IC isn't drawing any current to drop the voltage. This is the second IC. Just making sure it is in correctly. Thanks |
17th Aug 2016, 12:17 pm | #2 |
Re: IC polarity
Usually pin 1 is marked by a dot or a missing corner. So yes - I would assume that pin 1 is the one on the left in your photo.
17th Aug 2016, 12:28 pm | #3 |
Re: IC polarity
DIL ICs, such as that one,have pin 1 to the front LH side when viewed from above. As richrussell says, there is usually an ident such as a dot close to pin1, or often a small notch between the two end pins at the pin 1 end.
17th Aug 2016, 12:48 pm | #4 |
Re: IC polarity
But that looks like a SIL IC......
17th Aug 2016, 12:50 pm | #5 |
Re: IC polarity
So it does, in which case pin one is the left hand end, with the corner clipped. Duff batch or counterfeit chips?
17th Aug 2016, 12:51 pm | #6 |
Re: IC polarity
This might help.
17th Aug 2016, 12:52 pm | #7 |
Re: IC polarity
Reading the number as TA7318. AllDatasheet.com gives this PDF
http://www.alldatasheet.com/datashee...A/TA7318P.html Malcolm |
17th Aug 2016, 12:59 pm | #8 |
Re: IC polarity
Hya thanks all, yes it's a sil. I did look at the data sheet too, but thought maybe i was missing something.
Just wanted to make sure I hadn't woken up a bit more barking mad. Thanks |
17th Aug 2016, 1:38 pm | #9 |
Re: IC polarity
I see pin 1 as ground and pin 9 as Vcc
worried about the electrons entering the circuit and the smoke leaving Andrew |
17th Aug 2016, 4:50 pm | #10 | |
Re: IC polarity
Last edited by Guest; 17th Aug 2016 at 4:52 pm. Reason: Using works keyboard for ages, different spacing from the laptop, this edit explanation took ages to get right too! |
