Old 12th Jun 2019, 12:59 pm   #1
zifftoon
Default Tonearm Keeps Returning
I have an old Monarch turntable which works perfectly, except for the tonearm which keeps returning to the spinning record.
It happens when I use it in auto-mode, manual mode and also when I reject it.
How do I fix this issue?
zifftoon is offline
Old 12th Jun 2019, 3:14 pm   #2
julie_m
Default Re: Tonearm Keeps Returning
It is falsely thinking there are more records on the stack. Look for something not moving as freely as it ought to, connected with the overarm. It's held up above its normal position by the stack of records; when the last record has been dropped, the overarm falls back to the bottom and this is how the changer knows to shut off and not try to play another record.
julie_m is offline
Old 12th Jun 2019, 6:59 pm   #3
Michael Maurice
Michael Maurice's Avatar
Have a look underneath the overam, there should be a rubber collar (for want of a better word) on its spindle, it goes hard and breaks up which allows the overarm to drop further than it should.
Forum Moderator
Michael Maurice is offline
Old 12th Jun 2019, 8:41 pm   #4
Audio1950
Surely, if anything, that would make the mechanism shut down prematurely, which is the opposite of the fault the OP describes?
Audio1950 is online now
Old 12th Jun 2019, 11:34 pm   #5
Michael Maurice
No it doesn't actually, if you look at the shaft it has an indent, which when the arm is down with no records, allows a lever to move inwards. But indent doesn't go all the way down the shaft, so if the arm travels too far down, the lever that should move in, doesn't.
I'll post a picture tomorrow.
Forum Moderator
Old 13th Jun 2019, 12:47 am   #6
ben
ben's Avatar
That deck is a UA15. Have you removed the old hard (brown) grease from the mech?
Regards,
Ben.
ben is offline
Old 13th Jun 2019, 10:46 am   #7
Audio1950
Thanks Michael, I understand what you are saying. I'd forgotten that indent!
Old 14th Jun 2019, 11:00 am   #8
zifftoon
Is this the so-called "rubber collar" you are talking about?
zifftoon is offline
Old 14th Jun 2019, 11:04 am   #9
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
That's the one, but I've never known one of those go hard & brittle. Perhaps in the Malaysian climate this could happen, though.
'LIVEWIRE?' is offline
Old 14th Jun 2019, 11:09 am   #10
Michael Maurice
I’ve seen loads of them go hard and brittle, sometimes they’re not even there.
Forum Moderator
Old 14th Jun 2019, 12:59 pm   #11
tracypaper
tracypaper's Avatar
I'm with Michael, loads have gone hard and crack.
Looking at the corrosion of the overarm it suggest's it's been stood for years so would check for hardened grease as a starting point.
Gaz.
tracypaper is offline
Old 14th Jun 2019, 4:02 pm   #12
zifftoon
Which part of the mechanism should I check out for hardened grease?
zifftoon is offline
Old 14th Jun 2019, 4:19 pm   #13
Station X
Station X's Avatar
All of it!
Graham. Forum Moderator
Station X is offline
Old 14th Jun 2019, 4:56 pm   #14
zifftoon
Alright. I will do that.
zifftoon is offline
Old 14th Jun 2019, 7:29 pm   #15
Michael Maurice
Originally Posted by Station X View Post
All of it!
In fact, i strip them down to the bare chassis and clean everything before re-assembling with fresh grease.
Forum Moderator
