27th Feb 2021, 1:34 pm | #1 |
Garrard RC 80 problem
The problem is this: when started, the pick up arm moves across and drops on the record but instead of playing, after a second or two it lifts up and returns to the rest position. So somehow the auto stop mechanism is being activated prematurely, but I can’t see how or why.
Keep Calm and Carry On Restoring |
27th Feb 2021, 1:38 pm | #2 |
Re: Garrard RC 80 problem
Has this tuntable beeen cleaned and re-lubricated?
Cheers Mike T
27th Feb 2021, 1:56 pm | #3 |
I’ve cleaned and relubricated where I suspect the problem lies, but obviously not sufficiently...
27th Feb 2021, 2:07 pm | #4 |
I am no expert on these but when I had this problem it was the slides that start the cam had some oil on them they should be completely clean and free without lubricant.
Cheers Mike T
28th Feb 2021, 7:42 pm | #5 |
The problem is with the trip pawl. It works exactly the same as the more modern ones with a couple of plates that rely on friction and need to be completely dry and free from any oil or grease - have a read up on it in the 'stickies' if you're not familiar with them. The problem is that the mechanism on these early decks looks nothing like the later decks, but works in exactly the same way, so you'll have to look closely at it and work it out for yourself. Everything's adjustable on these decks, so if it hasn't had a known history of twiddling, then don't be tempted to go go screwing things or you'll never get it back to operating properly without a lot of fiddling about. I suspect that you've either got grease on somewhere you shouldn't have, or part of the trip is still stuck and needs freeing/cleaning...I've done a few of these in the distant past and you just have to get to know them. There's a 40 page service manual available from the forum link 'up top', but whether this will help you with this particular fault, I wouldn't like to say.
1st Mar 2021, 9:31 am | #6 |
Thanks Techman.
