30th Jan 2021, 1:07 pm | #1 |
Murphy A851G no sound to speakers. Tone arm fault on Garrard deck.
hello
i have a garrard a851g record player, im unable to get it to play sound through the speakers, the volume doesnt go up or down i can just hear the music from the record on the stylus. when i put a screw driver to the signal output connections on the arm i get no feedback, is the amp dead? ive been unable to locate the correct cartridge for it, i bought BSR SC12M ORIGINAL STEREO CERAMIC CARTRIDGE but it doesnt appear to fit my head shell. i fitted new valves EL84 Pentode Valve in B9A 12W AF Amp. the turntable was very sticky but i managed to get the turntable to spin nicely by cleaning the mechanisms and re-greasing. checked the speed and its around 44.5rpm. now i did put grease on the spring shaft for the lift mechanism for the arm, i have feeling this was incorrect? let me know if ive been a wolly haha the tone arm fails to go to the record player, it will lift up when auto is engaged but stops and hovers over the speed selection area then drops to there, it will however return correctly if it gets to the end of the record. hope you can help as im very lost with this now. i really need this working as its for a friend and hes itching to play 78's. thank in advance. |
30th Jan 2021, 1:56 pm | #2 |
Re: Garrard a851g no sound to speakers, tone arm fault.
Do you mean a MURPHY A851G?
Garrard did not make complete record players. A photo would help us to help you.
Edward. |
30th Jan 2021, 2:10 pm | #3 |
The Murphy A851G circuit I just look at uses two ECL86's
Interesting Cheers Mike T
30th Jan 2021, 2:12 pm | #4 |
Like this?
https://www.radiomuseum.org/r/murphy_a851g.html Do you still have the original valves? What did they say on them? They're unlikely to have been faulty, I'd say. |
30th Jan 2021, 2:18 pm | #5 |
If it is that model, service information is available here:-
https://www.service-data.com/section.php/5162/1/a851g
30th Jan 2021, 3:13 pm | #6 | |
Barry |
1st Feb 2021, 9:58 pm | #7 | |||
here are photos of the player. yes sorry it does say murphy on the amp cover but does also say garrard too. here are photos of it. thank you for all your replies i hope with your knowledge i can restore the sound and also build new knowledge myself too. Quote:
1st Feb 2021, 10:45 pm | #8 |
The arm that drops over the centre of the record senses whether there are any records to play automatically. If you use the short spindle the player will "think" there are no records there and the arm will do as you describe. If you use the long spindle and put the record so it sits on the little "sticky out bit" towards the top then put the second arm over it to hold it in position it should work.
However, there are some capacitors in the amplifier which should be changed. If you are very unlucky the failure of these my already have damaged the output transformer. Can you hear any hum or noise at all from the speaker with the volume turned fully up?
Paul |
1st Feb 2021, 10:53 pm | #9 | ||||
Cheers Mike T
2nd Feb 2021, 5:28 pm | #10 | |
Re: Murphy A851G no sound to speakers. Tone arm fault on Garrard deck.
Here are photos of the record player. also managed to find the old valves and they are indeed ECL86.
No I can't hear any feedback from the speaker when the record is running etc, both new valves glow nicely and warm up fine as I would expect. I have posted pictures of the amp. I hope we can restore the sound as it's such a lovely player |
3rd Feb 2021, 9:58 am | #11 |
Returning to your Post#1, that BSR SC12M is an ideal cartridge for your amplifier and will certainly easily fit the Garrard headshell. Did it come with a mounting bracket? If so, remove the headshell first (bayonet cap fitting) to make it easier and note the colour coding on the 4 connecting wires. Maybe make a diagram to remind you. I can see that you have the Centre Stacking Spindle (often missing) but are not using it.
Edward. |
4th Feb 2021, 12:08 pm | #12 |
Do you get a buzz from the speakers if you touch the centre tag of the volume control pot with a screwdriver?
If not it's time to get your meter out and take some voltage readings.
4th Feb 2021, 12:31 pm | #13 |
4th Feb 2021, 1:04 pm | #14 |
Ah, indeed it won't. As others have said the original valves are almost certainly ok. Contrary to popular opinion most valves are very reliable. In something like a record player which won't have been switched on for hour after hour they last almost for ever.
Put the original ones back and see what happens. Don't use it for long, though, as some capacitors will probably need to be changed.
Paul |
4th Feb 2021, 1:06 pm | #15 |
This chassis is exactly the same as that used in the Bush SRP31's.
The rectifier is bound to have failed, it can be replaced by a suitable diode and resistor in series. The two 50uF capacitors should also be replaced. As Nick has said, this will only work with ECL86's. |
4th Feb 2021, 2:01 pm | #16 | |
The Bush equivalents are still very commonplace, because they work well and are easy to repair. And there is a lot of advice available, both on this forum and elsewhere on the net |
8th Feb 2021, 6:07 pm | #17 | |
very much appreciate all of the replies, i have put the original EL86's back and i still have no sound from the speaker, i do not get a buzz from any point of the circuit when using a screw driver as before.
i see the reply about the rectifier i may need a little more help on this. again thank you all for your help it is more than appreciated. i want to play 78's! haha Quote:
fitting? is it just a case of soldering the connections to the new cartridge? thank you. i have just ordered 1N4007 and a 330 ohm 10W series resistor, i believe i have read correctly that they will be sufficient to bypass the rectifier? |
9th Feb 2021, 9:33 am | #18 |
You must NOT solder any connections to the new cartridge - it will ruin it. Please do send photos of the one you received.
Edward. |
9th Feb 2021, 12:56 pm | #19 |
I'd also change the 50uF capacitor visible in your second picture. It's been replaced before but will need doing again as it will have been many years ago. 47uF will be fine.
Your rectifier and limiter should be fine as should the ECL86s. Your cartridge should be connected via push-on connectors which will transfer to the new one. If they are missing then obtain new ones as soldering directly is certain death. |
9th Feb 2021, 6:37 pm | #20 |
So tha'ts a pic of the original cartridge and then a pic of the cartridge i bought. Unable to fit it to the current fitting.
