Old 16th Mar 2020, 4:58 pm   #1
Robinov
Default Goblin 854 Teasmade.
I have a 2 Goblin teasmades model No: 854. One of them has been working well for the last four years since I bought them but today has stopped. Light comes on, alarm works but the clock doesn't. I read previously that a judicious bit of lubrication can free the mechanism up but my question is how do I actually get into the clock? I am assuming the small round attachment on the back of the clock is the electric motor, is that correct. It is the clock mechanism I need to access. Any simple explanations out there? Cheers.
Robinov is online now   Reply With Quote
Old 25th Mar 2020, 1:18 pm   #2
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: Goblin 854 Teasmade.
It’s worth checking first that the motor coil hasn’t burned out. These motors are inherently very reliable, but an open-circuit stator is terminal. With the lamp and kettle off, simply measure the DC resistance between the live and neutral pins of the plug. A reading of 5 to 11 kilohms is normal, lower suggests shorted turns, higher (infinity) suggests a burnt-out coil.
If using a digital multimeter, use a high ohms range to avoid confusion.
Phil
“The place where optimism most flourishes is the lunatic asylum” - Havelock Ellis
Phil G4SPZ is online now   Reply With Quote
Old 25th Mar 2020, 2:55 pm   #3
Robinov
Cheers for that...I'll give it a go later and see the result. Are the motors available/repairable/replaceable ?
Old 25th Mar 2020, 3:29 pm   #4
Phil G4SPZ
Phil G4SPZ's Avatar
Sorry! Correction: I just checked my working 854 and it measures 18.9 kilohms.
Not sure about spare motors, but on-line suppliers like eSpares may be able to help. Try a Google search first.
Can you please post a picture of the motor once you’ve got the back off?
Phil
Old 25th Mar 2020, 3:57 pm   #5
Robinov
Sure thing. Cheers
Old 25th Mar 2020, 4:49 pm   #6
Phil G4SPZ
Phil G4SPZ's Avatar
Just found this on the web. There is a large 12k resistor in series with the motor, it’s worth checking that too as the motor itself might be OK. Otherwise, these motors appear to be made of Unobtainium...
Phil
Phil
Old 25th Mar 2020, 10:58 pm   #7
emeritus
When the clock of my mum's Teasmade stopped working, the cause turned out to be hardened grease on the motor's spur gear. Picking out the hardened grease with a sewing needle and re-greasing fixed it.
emeritus is online now   Reply With Quote
Old 26th Mar 2020, 12:15 pm   #8
You might find the "drop of oil" sorts it. The clock motor just lifts away if yoiu undo the two obvious fixing screws. Getting at the screws may be awkward, it was on my 860. Some of the info in here:
https://www.vintage-radio.net/forum/...d.php?t=163647
may help.....
Herald1360 is online now   Reply With Quote
Old 26th Mar 2020, 1:50 pm   #9
Robinov
Inside of teasmade.
Name:	Clock motor.jpg
Old 26th Mar 2020, 3:04 pm   #10
Robinov
Just tested as you mentioned and got a reading of 5.5
Old 26th Mar 2020, 3:09 pm   #11
Robinov
Unscrewed the motor and no stickiness or grease evident. Shaft turns freely.
Old 26th Mar 2020, 3:28 pm   #12
5.5 what? Ohms, Kilohms or Megohms?
Keep the soldering iron hot.
Old 26th Mar 2020, 4:16 pm   #13
Robinov
Reading
Old 26th Mar 2020, 4:18 pm   #14
5.46k or 5460R then. I'm assuming 'H' indicates that the HOLD Key has been pressed.
Does your meter have the 12k series resistor seen in post #6?
Old 26th Mar 2020, 6:10 pm   #15
Robinov
yes , exactly the same. see post 9
Old 26th Mar 2020, 6:15 pm   #16
Robinov
Would the difference in power supply come into the equation. I am in France so we have 230 V and 50 Hz.
Old 26th Mar 2020, 7:04 pm   #17
There is no significant difference in mains characteristics. Either there's an error in your measurement or you have a wiring fault. You should be measuring at least 12k.
Old 26th Mar 2020, 10:26 pm   #18
Robinov
Ill measure again in the morning.
Old 26th Mar 2020, 10:30 pm   #19
Measure across the mains plug, across the resistor and across the motor.
