17th Jun 2011, 2:39 pm | #1 |
Fixing Loose Valvebases
Has anybody succesfully used heat-shrink tubing to solve the problem where the cement has failed between the glass and the bakelite base? There have been various threads on here regarding re-gluing, with no real concensus of a good method. At least heat-shrink would be a removable repair.
Andy |
17th Jun 2011, 3:05 pm | #2 |
Re: Fixing Loose Valvebases
Hello,
I have a number of new old stock ex military valves with B4 and similar bases that have what appears to be thick heatshrink round the joint between base and glass. I presume it was put there by the military stores. I think it is probably being used prophylactically rather than to repair bases that were already loose. Yours, Richard |
17th Jun 2011, 3:08 pm | #3 |
Araldite works very well.
17th Jun 2011, 4:26 pm | #4 |
I have to say I think Araldite always looks messy if used for this! I also worry that Araldite is probably too strong and will stress the glass.
I have used 'Weldbond' which is a PVA glue which is easier to apply than Araldite (less sticky and water-soluble before it dries, I don't mind wiping it into place with a finger-end!), and dries completely clear. However, this has only been for valves I have put into my 'stores' - I don't know how well it will survive a hot valve in use. I think I will try to buy some suitably-sized heat-shrink and test it out in this application. Andy |
17th Jun 2011, 4:38 pm | #5 |
I dribble some cellulose lacquer down the gap, easy to get from a squirt of aerosol into the cap.
17th Jun 2011, 6:05 pm | #6 |
I pop a dab onto the end of a cable tie and "grout" the gap between the envelope and base.
17th Jun 2011, 8:58 pm | #7 |
If you're going to use the heat-shrink method it might be worth looking out for the type with adhesive on the inside.
Graham |
17th Jun 2011, 9:56 pm | #8 |
Another idea....high temperature silcon, the red stuff..this silicon will stick well to the glass envelope, this stuff will certainly take the temperature that most valves churn out. I have used it upto 200 c +
Cheers. |
17th Jun 2011, 10:53 pm | #9 |
I've successfully used clear nail polish [lacquer] It wicks down nicely between the glass and base and doesn't set too hard. I've also used it to stop arcing between tracks on a PCB.
17th Jun 2011, 11:37 pm | #10 |
Hello,
Here is a picture of a VR21 with what appears to be heatshrink. http://r-type.org/exhib/aaa0004.htm Yours, Richard |
18th Jun 2011, 10:55 am | #11 |
Another suggestion I have been given is to use shellac sanding sealer, as the original cement is shellac-based.
Lots of diverse ideas, thanks everyone. Andy |
18th Jun 2011, 2:00 pm | #12 |
What about superglue, it runs into every crevice, I swear by it, I dont see why it should not work for this application. As it is so runny it would also bond any of the original cement if loose or crumbling
18th Jun 2011, 3:21 pm | #13 | |
I wouldn't risk superglue on valves, even though the glass is thinner. Chris |
18th Jun 2011, 4:07 pm | #14 |
Superglue is not a good idea on valves due to the risk of cracking, (using it to stick mirrors on car windscreens can be equally disasterous! ) see also:-
https://www.vintage-radio.net/forum/...se+valve+bases Regards, Mick. |
22nd Jun 2011, 2:04 am | #15 |
fwiw I use standard Araldite around the joint but then bind 1 layer PVC electrical tape over the araldite. This forces glue into the joint. Leave it somewhere warm (hot water cupboard) 24 Hrs and then wind off the electrical tape. A nice fillet of glue remains.
