31st Dec 2012, 10:09 am | #1 |
Five band colour coded resistors.
Ok
So I show my ignorance again. I have a resistor here - it has 5 bands Brown 1 Red 2 Brown 1 zero Gold 5% Pink ? If I use a meter I get 120.4 ohm using a 4 band system I get 120 ohm at 5% What is that pink band about? SEAN
There are only 10 types of people, those who understand the binary system, and those who don't. |
31st Dec 2012, 10:20 am | #2 |
Re: Five band colour coded resistors.
I have a box of ex- GPO resistors and they have a pink band as well. I think it might indicate special quality grade components, but not 100% sure. Cheers, Pete
31st Dec 2012, 10:21 am | #3 |
Pink was used to designate 'high stability' in the says (days) when ordinary resistors were carbon composition.
Examples are the Erie 'cracked carbon' type, which may be what you are looking at. Modern film resistors are high stability by their nature. Andy |
31st Dec 2012, 10:22 am | #4 |
The pink, or more correctly salmon, was used to show that the resistor was of high stability.
Chris |
31st Dec 2012, 10:34 am | #5 | |
As usual - a very speedy response - thanks
I guess, like the % tolerance colour, there are are other colours used for this range - although a quick look on the web was not that fruitful..... until I added 'Salmon'. I have found this: Quote:
SEAN
31st Dec 2012, 11:01 am | #6 |
I was in the same dilemmer (dilemma) the other day, until I found this very useful website, put the colour's (colours) in and it tells you the value.
Must be my old age, I can't seem to remember as well as I used too. Paul. |
31st Dec 2012, 11:07 am | #7 |
It is fortunate that the sometimes unreadable 4 value + 1 or two other band resistors arrived at the same time as digital multimeters.
