21st Dec 2019, 12:40 pm | #41 |
Re: HP8504A Vector Voltmeter 1000MHz
@ Jeremy G0HZU_JMR: I was trying to send you a private message regarding your post about the HP8405A repair, but the system does not allow me. Could you please contact me.
Thanks & 73 de Andreas DG7RBN Last edited by Station X; 21st Dec 2019 at 2:18 pm. Reason: Post moved. |
21st Dec 2019, 2:18 pm | #42 |
Re: HP8405A Vector Voltmeter 1000MHz
Thread reopened.
22nd Dec 2019, 2:18 pm | #43 |
Wow, Looking at the start of this thread I've had my HP8405A VVM for six years now...
It's still working fine although I only use it a few times a year. There have been a couple of minor niggles over the years, I do recall that the phase meter started sticking and this was because the transparent dial coating was peeling away from the backing and it jammed against the meter needle. I managed to fix this by taking the cover off both dials and sticking the coating back down. I recall having to clean a couple of the switches as well. Hi Andreas, I can try and answer any technical questions but it's 6 years since I last looked at the inner workings of my HP8405A. So I may be a little rusty...
Regards, Jeremy G0HZU |
22nd Dec 2019, 5:19 pm | #44 |
I'm also observing this thread with interest. This summer I picked up an 8405A in good condition, though inevitably missing its accessories, at a very good price from an industrial auction. I haven't tried it out yet but had a look inside and one of the boards (I don't remember which) is labelled as faulty, so there's probably some work to do.
Chris
22nd Dec 2019, 5:42 pm | #45 |
Hi Jeremy,
read your interesting post about the HP VVM repair. Three weeks ago I also had one of these "good ol' boxes" on my bench for repair (from a Munich university, they use it to control a 70MHz resonator, they don't need a full blown VNA ). The -20V line was blown because of a shorted electrolytic. After complete recalibration it performs amazingly well above specs. The job would have been much easier with your "full-size" schematics, you mentioned in the thread. Could you please send me the file because I have a second HP8405A at the attic waiting for repair. The phase meter does wild swings and it also has the "flaky meter scale" problem. vy 73 and Merry Christmas Andreas DG7RBN P.S. I think I've found a solution for the dissolving meter scales. I've written a Postscript program to redraw the scales and print them. A laser marking shop in a town nearby will hopefully print them on adhesive foil with a cutout for the mirror arc. |
22nd Dec 2019, 9:57 pm | #46 |
Hi Andreas, I had a quick look and managed to find a GIF version of the big schematic. I've uploaded it here:
https://www.qsl.net/g/g0hzu//RF%20Tr...05A_bigCCT.gif This GIF version is a bit fuzzy but hopefully it is still very useful. If you open it in explorer it is possible to zoom in closer using CTRL and the mouse wheel. I did plan to try and find a paper copy of the HP8405A manual and scan it to produce a clearer version and one that includes all of the updates relevant to my particular serial number/year. But so far no luck...
22nd Dec 2019, 10:42 pm | #47 | |
Chris
22nd Dec 2019, 11:00 pm | #48 |
My repair to the dials was a bit more of a bodge. I got an old Pritt stick and made up a weak solution of 'Pritt' by adding some water to a few scrapings of Pritt. I then made a crude liquid dropper and the weight of the tiny drops of the weak Pritt solution was enough to secure the original display film back down. Otherwise, any attempt to even lightly touch the transparent peely bits of the film would result in them fragmenting to nothing. The results were very good and so far the display has not yellowed.
23rd Dec 2019, 1:10 am | #49 |
I have a vague recollection of a mention in a 1970's HP catalogue of their meter scales being individually calibrated, but this might have been for a particular instrument rather than general practice.
3rd May 2020, 2:23 pm | #50 |
I am repairing a hp8405 and when I tried to adjust mechanical zero
I discovered that the amplitude meter is not a linear galvanometer….a the begining it requires250ua (-9dB) at the center 500ua (-3dB) and full range 1mA(+3dB). The scale is quite perfectly linear in dB but not exactly and it shall be possible that each was individually calibrated. The magnetic circuit has a spécial shape to bring this log response. Regard Jean-Louis |
