29th Dec 2017, 12:15 pm | #1 |
Log pot using a linear one
I want to build a little audio mixer for my Grand-son. Ideally passive. I bought some cheap pots off ebay - all the cheap ones seem to be linear. I opted for 10k but I think 100k would have been a better choice.
Be that as it may, I'd like to approximate a log progression by simply using a fixed resistor from wiper to one end. The attachments show my calculations using various fixed resistors. Is there an easy way to tell if any of them come anywhere near a log curve? Could be more widely useful than just this query. Graham
Half my stuff is junk - trouble is, I don't know which half! |
29th Dec 2017, 12:25 pm | #2 | |
Re: Log pot using a linear one
Then click on Google images. EDIT: Taper resistor usually 20% of the track value. Lawrence. Last edited by ms660; 29th Dec 2017 at 12:49 pm. |
29th Dec 2017, 12:57 pm | #3 |
Is this any help?
PMM |
29th Dec 2017, 1:41 pm | #4 |
Pse don't forget that the impedance of the pot + resistor with vary with pot position, reaching a minimum of about the 80% of the resistor value at max volume. You will end up with 1.6k for the example above.
Ken |
29th Dec 2017, 2:56 pm | #5 |
It will be a reasonable approximation of a log pot. It'll be good enough I expect.
29th Dec 2017, 4:12 pm | #7 |
Useful comments and links all. Thanks so much. The Google search suggested also provided this link:
https://www.maximintegrated.com/en/a...dex.mvp/id/838 which suggests another configuration, namely series resistor plus linear pot wired as a variable resistor. I guess that's a current/voltage "dual" cf the normal arrangement and might help with the variable input z which I hadn't considered. As a simple try-out, the 2k2 option looks like it'll behave well. Thanks again. Hope others find this refresher useful! Graham
29th Dec 2017, 4:40 pm | #8 |
If you want to use the ones you've got, you could also use an active Baxandall gain control circuit, which gives a log law with a linear pot. See here (scroll down about a third of the way): http://sound.whsites.net/project01.htm
This is also good bed-time reading: http://www.ti.com/lit/ug/tidu034/tidu034.pdf It's easy to be put off by these circuits as they require op-amps, but you'd require those anyway to make a mixer. Trying to keep it entirely passive is fraught with complexity. More about mixing circuits here: http://sound.whsites.net/articles/audio-mixing.htm Alternatively, buy some 100k pots, and feed each one of those into the 10k input resistors of a virtual earth mixer (figure 4 at above link). Only 1 op-amp needed (2 for stereo), and Zin remains at 9k or more (put 1k in series with the 100k pot to ensure it never goes below 10k, or use 12k instead of 10k for the mix resistors). As a rule of thumb, line inputs should be 10k or more, so this will be fine. If you want to use the 10k pots in a circuit like this, you'll need to buffer them first, and then use ~1k mix resistors. An emitter follower would be OK, and the biasing components could be shared between channels... Whichever you use, watch out for DC currents in the pots - these wreck 'em! |
29th Dec 2017, 6:53 pm | #9 |
Un-switched log pots (and lin) in a range of values are only 85 pence each from Bowood Electronics, (no VAT, Min order value £5.00). £2.85 P&P:
https://www.bowood-electronics.co.uk...cfbe639965e0fd Hope that's of interest.
30th Dec 2017, 12:10 am | #10 |
Does this help?
