16th Dec 2017, 1:41 pm | #1 |
Triode curve tracer
Hi, I was just wondering if with sutable buffering if a Peak Atlas component tester could analyse a triode. Lots of other ways to achive without zapping a Peak Atlas analyser I know, but just a thought.
Overview attached. Pete |
16th Dec 2017, 4:36 pm | #2 |
Re: Triode curve tracer
Looks promising, maybe add series resistors from the (expensive) DAC too.
17th Dec 2017, 7:36 am | #3 |
Interesting idea, how would you make the buffers? There's a high voltage opamp - LTC6090 made by Linear that may do the job.
Andy.
17th Dec 2017, 9:22 am | #4 |
As part of the process of designing homebrew amplifier, I needed some plots of cathode current against grid and anode voltages. I used the ADCs and one DAC of a Velleman K8055 interface board, with a dual op-amp to level-shift the grid voltage (I didn't need to go below -9V) and amplify the voltage developed across a 10Ω resistor in the cathode, with just a simple potential divider to get the anode voltage.
The worst bit really was getting power into the whole arrangement ..... Were I doing it all over again, I think I'd use a HCPL7800 or similar to measure the current through a sense resistor in the anode, so the arrangement could be extended to tetrodes and above without G2 current affecting the readings; and connect a couple of relays to the digital outputs, to switch the HT and heater supplies.
20th Dec 2017, 1:28 pm | #5 |
By coincidence the November 2017 VMARS "Signal" journal dropped through the letter box today with an article on a microprocessor controlled valve curve tracer.
Pete |
