28th Jul 2017, 11:48 am | #1 |
NuTube miniature double triode
28th Jul 2017, 12:27 pm | #2 |
Re: NuTube miniture double triode
Cool ! I've so got to get me one of these - not for any audio reasons, simple what an interesting looking device.
TTFN, Jon |
28th Jul 2017, 7:51 pm | #3 |
I seem to recall an earlier thread about that. It is essentially a rework of a display device, to provide a rather puny triode for use in an effects box masquerading as an audio preamp.
28th Jul 2017, 9:08 pm | #4 |
I remember the earlier thread, you could do the same with a multiplexed VFD and have a few common cathode triodes. Some with two anodes some with two grids depending on how you wire it up. The anodes would glow as well!
28th Jul 2017, 9:11 pm | #5 | |
Upon reading some of the 'literature' about the 'tube' this popped up...
28th Jul 2017, 9:44 pm | #6 |
Oooh and it ticks the directly heated box as well!
Some people could get a little overheated about it. However, it needs to have a plug-in ZIF socket so they can spend hours comparing the acoustic signatures of different date codes. I wonder what happened to those field emission devices which emitted electrons from a 2-dimensional array of cold spiky points? David
29th Jul 2017, 10:52 am | #7 |
It is a good example of how capitalism doesn't just force the market to meet buyers' needs, but also persuades buyers to meet the producers' needs.
29th Jul 2017, 8:19 pm | #8 |
Yep- there must be a fair amount of VFD manufacturing plant that isn't quite as busy as it used to be and this looks like a handy means of extending and maximising return on investment.
Every few years, a "miniature cold-cathode device" story pops up, and then things go quiet again. Either it's a non-starter (balance of probability?), or it's very significant indeed and gets sat on (in the way that the Russians noticed that nuclear research articles disappeared from American scientific journals post-1942....) Last edited by turretslug; 29th Jul 2017 at 8:25 pm. |
29th Jul 2017, 9:31 pm | #9 |
It is obvious that field effect and transistor electrons are cold, ones emitted by a hot cathode are much better.
29th Jul 2017, 10:57 pm | #10 |
The Vox MV50 series uses them, here's a demo with the Vox MV50-AC which has the Nutube in it...Luv it:
https://www.youtube.com/watch?v=DY5AlUj0i2c Anyone fancy building a regen receiver with one? Lawrence. |
30th Jul 2017, 6:26 am | #11 |
I rather liked the bit about the device being microphonic, so you should attach a piece of lead to it to damp out problems.
30th Jul 2017, 7:02 pm | #12 |
Re: NuTube miniature double triode
I agree with Duke_Nukem above that it looks really cool as esoteric, it doesn't look like a VFD, really, and not like anything else either.
But, honestly, is this not a bit of a gimmick? Sure it certainly provides some sort of 'vacuum tube sound' but I would think it has a sound of its own rather than accurately reproducing that good ole overdriven valve amp sound. |
30th Jul 2017, 7:19 pm | #13 | |
[IMHO if an amplifier has a detectable "sound" then it's in need of major rework to improve its linearity!] |
30th Jul 2017, 7:28 pm | #14 | |
30th Jul 2017, 7:36 pm | #15 | |
Personally, I don't think the current US-owned Vox products hold a candle to the original UK-made Jennings products, but then I am British and an owner of an AC30 - so I'm biased. Colin. |
18th Dec 2017, 2:01 pm | #16 |
VFD based triodes - has anyone tried them
Apologies if these have been mentioned before, but this look interesting (if a bit expensive):
https://uk.rs-online.com/web/p/doubl...alves/1449016/ Reading between the lines, "gives just as much distortion as a conventional valve amplifier". Must be good then. Glows just like the real thing (but in green). As anyone knocked up a circuit to see if they work? |
18th Dec 2017, 2:57 pm | #17 |
Re: VFD based triodes - has anyone tried them
The emails I get from RS have links to a Designspark project using this VFD triode, they are only building a guitar pedal with it though;
Links to the project so far; Part 1 https://www.rs-online.com/designspar...-1-tube-basics Part 2 https://www.rs-online.com/designspar...rt-2-prototype Part 3 https://www.rs-online.com/designspar...&bid=539491908 David Last edited by factory; 18th Dec 2017 at 3:06 pm. |
18th Dec 2017, 4:40 pm | #18 |
There was a thread about these a few months ago. They are essentially a 'toy' item, to keep the VFD productions lines going. Rumoured to be microphonic too.
18th Dec 2017, 8:48 pm | #19 |
Threads merged.
18th Dec 2017, 9:51 pm | #20 |
Hi Gents, I think I'll market a board with one or 2 EM81/82 valves on it. That should tick all the boxes.
Ed |
