Old 13th Mar 2019, 1:11 pm   #1
Draker4c
Default Bulbs for Racal RA1772 encoder unit
Has anyone got any idea where I could obtain suitable 690w 14v replacement filament bulbs for the RA1772 encoder unit? Would leds be suitable replacements
and if so what type?
Thanks
Hugh G1AUR
Draker4c is online now
Old 13th Mar 2019, 1:39 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Bulbs for Racal RA1772 encoder unit
I think these are they: https://vintage-radio.net/forum/showthread.php?t=114340
Farnell also have them: http://www.farnell.com/datasheets/29809.pdf
AC/HL is offline
Old 13th Mar 2019, 2:46 pm   #3
Herald1360
Herald1360's Avatar
Farnell link only goes to datasheet. The Farnell cat. no. there is no longer recognised.
There is this:
https://uk.farnell.com/lux/n9951903/...m%2Fw%2Fsearch
but there's some confusion as to whether it's 14V or 24V!
Or you could get inventive with these, perhaps?
https://www.ebay.co.uk/itm/LAMP-T1-1...EAAOSw-jFZ6etF
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 13th Mar 2019, 3:38 pm   #4
Draker4c
Many thanks for your advice gentlemen!
73
Hugh G1AUR
Old 13th Mar 2019, 4:35 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
An LED and a resistor ought to last indefinitely. As the sensor will be a phototransistor, it's worth looking up it's spectral sensitivity and picking an LED to suit the best wavelength.
Radio Wrangler is online now
Old 13th Mar 2019, 8:51 pm   #6
emeritus
Tubular 14V LES bulbs were used in the car radios made by for Ford by Plessey in the late 1960's I have a couple somewhere in the loft that I will never use again and could salvage the bulbs from them. I am not familiar with the Racal encoder unit. Is the bulb wattage/current and envelope configuration critical? How many do you need? Somewhere I do have some low wattage LES bulbs that I got some years ago for the dolls house I made for my daughter and must have some spares somewhere, but I think they are 12V. A bit busy decorating at present but I can have a look at the weekend if you can't find anything suitable.
emeritus is offline
Old 13th Mar 2019, 9:40 pm   #7
Sparky67
Sparky67's Avatar
There is some dicussion on the RA1772 and encoder LEDs HERE.
Martin
G4NCE
Sparky67 is offline
Old 13th Mar 2019, 11:23 pm   #8
emeritus
While looking for something else, I found a box with a couple of NOS 14V 0.75W LES bulbs (RS code 586 093) that I have had for more than 40 years and not needed. If they are any use, PM your address and I will stick them in the post FOC.
emeritus is offline
Old 15th Mar 2019, 7:58 pm   #9
Sean Williams
Sean Williams's Avatar
I reckon this is close enough - draws a little more current, but that shouldnt be an issue
https://www.ebay.co.uk/itm/14v-50ma-...frcectupt=true
Sean Williams is offline
Old 23rd Mar 2019, 8:50 pm   #10
Draker4c
Thanks to everyone for response and apologies for all advice and offers.I should now be able to find the type. Emeritus thanks for your offer apologises for late response..call of work...!
73
Hugh G1AUR
