Reply
Old 22nd Sep 2023, 7:16 pm   #1
Jonnie 5
Default Binatone hi fi
Hi all.
My son just bought this of eBay.
The lady said it needs a belt.
New belt fitted. Swapped the motor for mine.
Still plays records slow.
I think the circuit board maybe the issue.
Does anyone know anything about them or where I might be able to get a second hand one.
Thanks in advance
Ps I try to add some pics
ID:	285408   Click image for larger version
ID:	285409   Click image for larger version
Jonnie 5 is offline   Reply With Quote
Old 22nd Sep 2023, 7:56 pm   #2
Audio1950
Default Re: Binatone hi fi
The third picture shows the 45 and 33 adjustment controls. Turn each one in turn a tiny amount, test and adjust again as necessary.
Barry
Audio1950 is offline   Reply With Quote
Old 22nd Sep 2023, 8:10 pm   #3
Jonnie 5
Hi Barry.
Thanks for reply.
In pic 2 below the 94hb I think that part maybe broke as it doesn't do anything
Old 23rd Sep 2023, 11:51 am   #4
Beobloke
Originally Posted by Jonnie 5 View Post
Hi Barry.
Thanks for reply.
Unless there’s some part of it missing, I can’t see that it will ever do anything.
Beobloke is offline   Reply With Quote
Old 23rd Sep 2023, 11:53 am   #5
Station X
Station X's Avatar
Is it a switch or a pot? If a pot it has no track.
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 23rd Sep 2023, 12:19 pm   #6
ms660
ms660's Avatar
The wiper of the control on the track side looks like it's connected to the reference pin 5 of the motor control IC, speed selector switch.
Lawrence.
ms660 is offline   Reply With Quote
Old 23rd Sep 2023, 12:24 pm   #7
SiriusHardware
It is clearly a rotary switch with a wiper which makes contact with the surrounding plated PCB tracks, similar to what you'd find on a multimeter range switch.
However, it only has one point of contact, I suspect there should actually be two sprung contacts 180 degrees apart so that the plated PCB track on the left is joined to one of the three on the right, depending on the position of the switch. Could this be the speed setting switch? If so, there is no point in messing with the speed setting pots for the time being.
Unless the OP has the means to fabricate a replacement switch contact, I think this may have to go back to the seller (if possible).
Edit: Crossed with Lawrence.
SiriusHardware is offline   Reply With Quote
Old 23rd Sep 2023, 12:38 pm   #8
Station X
Station X's Avatar
The switch must be connected to an external control. Does operating this control change the speed significantly?
Old 23rd Sep 2023, 1:33 pm   #9
Jonnie 5
Hi all.
No speed change. And have found the other half of that piece in the bottom of the unit.
Can you still get parts like that or even a secondhand board?
Thanks
Old 23rd Sep 2023, 1:43 pm   #10
Station X
Station X's Avatar
Can you temporarily bridge it to see if one speed is correct?
How about posting a picture of the broken off piece.
Old 23rd Sep 2023, 2:56 pm   #11
Nickthedentist
Nickthedentist's Avatar
This era of BSR decks were always troublesome in this department. I’m sure you’ll be able to repair it though.
The only source of spares is likely to be another similar system. There were a lot made by companies like Amstrad and Solavox but most will have been thrown out 25 years ago or more. I still see them occasionally in charity shops which do house clearances.
Nickthedentist is offline   Reply With Quote
Old 23rd Sep 2023, 3:55 pm   #12
Jonnie 5
Thanks all for replays.
I might try and fabricate something to do the job.
Thanks again
Old 23rd Sep 2023, 4:05 pm   #13
Michael Maurice
Michael Maurice's Avatar
Default
Thanks again
You don't need to fabricate anything
I recently serviced a similar unit. You will find the centre bit is the common bit, it doesn't look like anything has broken off.
Does the speed change when you operate the switch?
If yes then fine adjustments are carried out by the two presets, if no there is a fault and you'll need a multimeter to check
If you look at the picture of your board that I've posted, the tab that's sticking out of the switch must be on either the 45 or 33 contacts indicated by the blue and red lines. The green line is the common bit.
Forum Moderator
Michael Maurice is offline   Reply With Quote
Old 23rd Sep 2023, 4:08 pm   #14
Station X
Station X's Avatar
The OP says that operating the switch doesn't change the speed. It would be useful to carry out continuity tests on the switch.
We don't yet have a picture of the broken off part.
Old 23rd Sep 2023, 4:34 pm   #15
ms660
ms660's Avatar
Looks like one half of the wiper has broken off, revealing a thin plastic interface washer underneath, the broken off bit should also have a wiper tag looking at the wear pattern on the PCB switch contacts (RH side in the OP's photo)
Lawrence.
Old 23rd Sep 2023, 7:38 pm   #16
Jonnie 5
Hi all
Yes half has broken off. Son has lost it.
Thanks for your help.
I'll take it out again and see what can be cobbled together
Old 25th Sep 2023, 7:37 pm   #17
Jonnie 5
Hi all
Has anyone got a picture of the wiper bit that's missing or is it a mirror image?
Old 25th Sep 2023, 10:49 pm   #18
Michael Maurice
What I would do is to throw away what’s left of the switch, and fit a miniature rotary switch in its place.
Forum Moderator
Old 26th Sep 2023, 7:47 pm   #19
Jonnie 5
Hi all again.
Just a quick update
Managed to get the rpm switch to work now.
Fitted it back together.
Both rpm speeds are alot slower than they should be. Twiddled with the fine adjustments and no difference.
One thing I did notice is when you first move arm to start it off. For a split second it turns quicker before slowing down.
Any ideas or where to go next would be appreciated.
Thank you all
Old 26th Sep 2023, 9:40 pm   #20
ben
ben's Avatar
Using a small flatblade screwdriver, adjust the pots in the orange box on the picture until the speed is right. Ideally compare the record with a cd or mp3 playback of the same song.
Regards,
Ben.
ben is offline   Reply With Quote
Reply
