Old 10th Jun 2018, 1:10 pm   #1
Diabolical Artificer
Diabolical Artificer's Avatar
Default Marconi TM6113 choke adaptor.
I have a Marconi TF2700 LCR bridge which you can get an adaptor for so you can measure inductance with a DC bias. I've searched a lot for one, or for a schematic, but the best I've found is a schematic without value's in the TF2700 manual.
What inductor's/caps could I use for the two L/C's in parallel, the ones in series with the bias PSU? If I had a handle on those I could make a homemade TF6113. I presume a 10n would do as the cap across the supply and a 0.1u 630v as the blocker on the RHS.
Re measuring tfmr's, I've had great difficulty using my TF2700 as well as another L meter i have. I get a different result every time. There's a video here - https://www.youtube.com/watch?v=s62DL_v5zRg that goes into a bit of detail and a method of measuring said tfmr's.
Andy.
Name:	Screenshot from 2018-06-10 13-04-40.jpg
Diabolical Artificer is online now
Old 10th Jun 2018, 1:16 pm   #2
ms660
ms660's Avatar
Default Re: Marconi TM6113 choke adaptor.
https://www.vintage-radio.net/forum/...ad.php?t=99238
Lawrence.
ms660 is offline
Old 10th Jun 2018, 2:09 pm   #3
Don't know what happened there Lawrence, I searched here first. Thanks.
Andy.
