29th Sep 2014, 2:45 pm | #1 |
Philips N4404 earthing
I am gradually bringing this machine back to life and upon checking the mains cable, it is 2 core only (black and blue !) so no mains earth. This looks original and no mains earth is shown on the schematic. It also has the inevitable 13A fuse in the plug. So, should I install a 3 core flex and earth the chassis ?
Rgds Ken |
29th Sep 2014, 10:13 pm | #2 |
Re: Philips N4404 earthing
You should fit a 3A,2A, or even 1A fuse in the plug as standard procedure. There is no need to earth the chassis for safety, although there may be a slight reduction in hum.
If you connect it to another earthed bit of audio equipment it will be earthed through the audio lead -if both were earthed at the mains plug you may have hum problems. Some of the earlier Philips machines had mains leads with 2 white cores so I would not worry (black and blue predated the convention, but seen in Europe; black = live) |
30th Sep 2014, 7:26 am | #3 |
Thanks for the response. Fuse done of course but will now leave the flex original.
Ken |
