Old 7th May 2008, 10:02 pm   #81
MALC SCOTT
MALC SCOTT's Avatar
Default Re: Missing Sets?
Hi Steve, it was the BRC 8000 chasis.
Malc Scott
MALC SCOTT is offline
Old 8th May 2008, 8:21 am   #82
Mike Phelan
Mike Phelan's Avatar
Yes - Malc's right. Most BRC colour sets had the red button - the 8000 was to proclaim that the LOP transistor had failed, usually. Best forgotten ...
Mike.
Mike Phelan is offline
Old 8th May 2008, 1:12 pm   #83
Welsh Anorak
Welsh Anorak's Avatar
Hi Steve
Yes - that was the famous 17" 3717 introduced in late 1971 - the first 'under £200 set' produced that wasn't a portable. It looked dated even then! It had a rubbish unipotential tube in it that always went a greeny-blue with brick-coloured reds - I think it might have been a Toshiba. The 8000A had a proper tube in it!
The 8000 has its fans, but it was a basic set - mechanical tuner, thyristor PSU hidden in the depths that cooked, awkward line output transistor (type and accessibility!) and a bit of a home-made chassis look about it, especially if you were used to the 3000 series. Oh - it had a doubler as well - if anybody needs one I have a couple of NOS ones....
Glyn
Welsh Anorak is offline
Old 9th May 2008, 10:16 am   #84
ianj
I thought that Decca had a sub-£200 colour set on the market about this time? ianj
ianj is offline
Old 9th May 2008, 10:27 am   #85
gec2110
Originally Posted by Welsh Anorak View Post
Hi Steve
Glyn
HMV made the same set with a totally wood cabinet
and no frame around the screen; the screen was very round
the pictuer gometary was awful this set was worse than the pye chelsea
and that was bad the plastic back cover was good though
gec2110 is offline
Old 9th May 2008, 11:16 am   #86
Tazman1966
Tazman1966's Avatar
Wasn't this the CS1730? This also used the poor low focus voltage tube but was pretty reliable.
All the very best,
Tas
Tazman1966 is offline
Old 9th May 2008, 11:27 am   #87
Tazman1966
Tazman1966's Avatar
the picture geometry was awful. this set was worse than the pye chelsea
and that was bad. the plastic back cover was good though
I seem to remember a thread that Marcus3500 had about his. It included some pictures too but I can't seem to find the thread. I'm sure I didn't dream it
All the very best,
Tas
Old 9th May 2008, 3:10 pm   #88
Studio263
Studio263's Avatar
Do you think of the Sony KV1320UB (yours for a shade under £200 sir...) as a portable? I know some do but it's jolly heavy, has a wooden cabinet and most importantly, no handle!
It's also a properly engineered product made with high quality componets and fitted with an excellent tube that can produce really first class results. You can't say any of that about the BRC8000!
Studio263 is offline
Old 9th May 2008, 10:08 pm   #89
Tazman1966
Tazman1966's Avatar
I found the picture of Marcus's TV that I was refering to earlier. I had saved it to my computer as I liked the look of this set. (Ducks for cover!)
I wonder how Marcus is getting on with this set?
All the very best,
Tas
Old 10th May 2008, 9:02 am   #90
Mike Phelan
How about the strange little hybrid Teleton with the funny valves? Quite a decent picture and very reliable. Forgettory has swallowed the model number - I seem to think it had touch tuning using 7400 TTL chips?
Mike.
Old 10th May 2008, 9:30 am   #91
Steve_P
Steve_P's Avatar
Go to Mikey405's site for a picture. The set is a VX1110 and the set had the 10 Pin Valves - the one you have probably heard of is PFL200. The valves were quite difficult to get hold of, but not impossible. They were quite reliable valve wise, but like every other set, go for Capacitors.
Steve P.
Steve_P is offline
Old 10th May 2008, 12:42 pm   #92
Mike Phelan
Steve
You're right about the VX1110, but I'd call a PFL200 a "normal" valve.
It was things like the 3AT2 EHT reccy and its pals I was referring to. Lee (Hunts smoothing bomb) has/had one of these sets: as in Post #9 here.
Mike.
Old 10th May 2008, 7:30 pm   #93
Colourstar
Colourstar's Avatar
Just wanted to say a belated thank you to Malc, Mike and especially Glyn for identifying the Ferguson 3717. I never knew there was an HMV version too. I suspect both versions must surely be extinct by by now, but does anyone have any brochure shots!
These sub-20" early 70s colour sets make for an interesting topic. I'd forgotten about the little Decca model and didn't Pye do a little hybrid 18" set too around the time of the CT205 and indeed sharing the same 6 button tuner? I have a 1973 brochure which includes the Invicta version of it (on legs!) - probably about the last year the Invicta named was used appeared....
Steve J
Colourstar is offline
Old 10th May 2008, 7:32 pm   #94
Colourstar
Colourstar's Avatar
I think that last sentence should read ' probably about the last year the Invicta name was used' ...
and I have touched a drop (yet)!
Steve
Old 10th May 2008, 8:10 pm   #95
Colourstar
Colourstar's Avatar
And after a quick delve in the leaflet drawer, some illustrations of a few oddities...
Photos show what I assume is the Alba TC2417 which must be a version of the Ferguson 3717 alluded to earlier, then the Invicta 7018 18" colour set (1974), the Ekco CT818 18" (nice legs!), Ekco's 1972 'Leap Ahead Year' TV promotion including the CT253 in trendy white... or CT252 in black.Steve
ID:	17070   Click image for larger version
ID:	17071   Click image for larger version
ID:	17072   Click image for larger version
Old 10th May 2008, 9:13 pm   #96
thermionic
thermionic's Avatar
No one would shed a tear if that Invicta disappeared for ever. Containing - I suspect the Pye 713 chassis.
I suppose the whip is a handy accessory - just right for caning the beast!!
Simon T.
The honesty of imperfection..........
thermionic is offline
Old 11th May 2008, 9:53 pm   #97
BGmidsUK
That Alba set looks very much like a set we rented for some years, if I remember right. A new tube was fitted after a while since the old one was flaring badly and the picture with the new CRT was fantastic. Visitors often commented on the excellent quality!
BG
BGmidsUK is offline
Old 12th May 2008, 10:48 am   #98
ianj
What was the range of sets in the 1960s/1970s that had a reset button on the back panel...............we had one but never had to press it in anger! ianj
ianj is offline
Old 12th May 2008, 12:42 pm   #99
MALC SCOTT
MALC SCOTT's Avatar
Hi, BRC 3000/3500/8000/8500/8800/Rediffusion mk1.
Malc Scott
Old 12th May 2008, 3:36 pm   #100
Welsh Anorak
Oh how we miss the CT200 series....don't we??
I'll bet it was a simulated picture as they never produced a viewable one...
I think these sub-£200 sets came after the 8000 in late '71, so I think the claim was justified!
Dragging the thread kicking and screaming back on-topic, I know there weren't so many of the early seventies European hybrids imported (as opposed to the big names), but I quite liked the Skantic/Luxor (with the odd PC92 and three colour difference EF184valves), the Saba hybrid (weighed a ton but very reliable) and even the Kuba Florence! But the most common I havent seen for a long while is the good old Korting hybrid. Took ages to warm up due to the heater thermistor but a great picture and reliable as well. Anyone got one?
And am I imagining things but (challenge time) was there a hybrid set which used RGB drive with THREE PL802s? Just me, then....
Glyn
