12th Nov 2019, 2:15 pm | #1 |
Mullard MAS 61 next project help
This the next big project i am going to start, i got this last year and now its going to be my winter project.
It has a Mullard label on it (see images) it looks very Phillips like , of which i seem to be drawn to as most of my collection are Phillips. I am struggling to find any info , schematic etc for it Does anyone know if it is a phillips badged mullard and if so what chassis it is based on It needs a good clean inside and out , along with the usual cold checks , the tiny knobs are bass and treble controls with a little glass window below the controls with little curtains move in tandem with the controls movement. Regards mark |
12th Nov 2019, 2:38 pm | #2 |
Re: Mullard MA61 next project help
It's a MAS61. I suspect the chassis corresponds to some B3Gxx model (maybe B4Gxx), though the power transformer and coil cans carry Dutch code numbers, indicating the origins of their design. If I read the date codes correctly it could be built as recently as 1963, though it looks more like late 1950's to me.
Does it have FM (VHF)? What's the valve complement? Is there a black label on the inside of the back panel? Last edited by Maarten; 12th Nov 2019 at 2:58 pm. |
12th Nov 2019, 2:48 pm | #3 |
The Phillips B5X72A looks like the same chassis but with just one speaker, worth looking into.
https://www.radiomuseum.org/r/philips_b5x72a.html
Clive |
12th Nov 2019, 4:10 pm | #4 | |
No black label on back panel Valves see image below |
12th Nov 2019, 4:15 pm | #5 | |
12th Nov 2019, 5:23 pm | #6 |
Re: Mullard MAS 61 next project help
Hello
See https://www.radiomuseum.org/r/philips_b6if72a.html - also for a schematic. Best regards, Walter |
12th Nov 2019, 5:46 pm | #7 |
Thats the one thank you, have managed to get the schematic but am not a radio museum member so cant get more than 3 pages, will look at list on Paul's data dvd and if is will order a copy.
Maarten You were spot on with the age. |
12th Nov 2019, 7:22 pm | #8 |
The EBC81 looks down to air unless it is just dusty!
Geoff |
12th Nov 2019, 7:49 pm | #9 |
Too new to radio restoration to know that so have cleaned it gently and taken a pic and would appreciate your opinion on its condition
Regards mark |
12th Nov 2019, 7:51 pm | #10 |
No black sticker, but the white sticker also carries a Dutch code number, which what I was looking for (British made sets mostly had a British code number on said sticker). The Irish origin makes sense. They often used Dutch designs for their sets. Sometimes modified or developed further.
12th Nov 2019, 8:26 pm | #11 |
A valve has vacuum when the top has black shiny 'getter' like the other valves in the radio. This turns white if air leaks in. The valve you have appears to be clear so may have leaked so could be faulty. If you are new to radio repairs and restoration it would be beneficial to read these pages first.
http://www.vintage-radio.com/repair-...ion/index.html http://www.vintage-radio.com/repair-...lves-work.html
Geoff |
12th Nov 2019, 10:14 pm | #12 |
I suspect the valve is OK....some had getter on the side and I think if you look carefully there is some silvering on the side. Some 'Valvo' brands were like that. The proof will be when power is applied. If it lights up then it has vacuum.
12th Nov 2019, 10:34 pm | #13 | |
Thanks for the links i will read them and learn from them if the grey cells retain it is another matter . I am new to radio restoration but not electronics , my knowledge though is in modern electronics, including microprocessors such as pic, arduno , rpi etc Valve radios and their bringing them back to life both fascinates me and scares me a little. I am keen to learn and understand the dangers so i will read lots , scour this forum for advice , hopefully at the same time give something back to the forum as i believe help should be a two way thing. I have at present around eight radios and a schaub lorenz 5000 which i think for its time was amazing. My aim is to slowly try and bring back to life as many of the radios i have as is possible. |
12th Nov 2019, 11:27 pm | #14 |
Searching for the code number on the valve complement sticker comes up with the B4X99A, which has an extremely similar chassis. This is a Dutch export model from 1959, so it's safe to say they were based on a common design.
13th Nov 2019, 9:46 am | #15 | |
Yes one side does look silvery so could still be a good valve. Nothing to loose by trying it. Before anything else though some of the capacitors will need replacing.
Geoff |
