Old 30th May 2023, 5:11 pm   #1
geoff1234
Default Philips cd100 servo board timer device
Does any one have any information regarding how to read the small glass cylinder device that is present on the servo board of a Philips CD100. Its not mentioned in the circuit or service manual. Its obviously measuring something but its not obvious how to read it. I attach a picture of it.
Name:	time device.jpg
geoff1234 is offline
Old 30th May 2023, 6:35 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Philips cd100 servo board timer device
Its an elapsed time indicator.
Often used where items have a known or limited lifespan in industrial, commercial and military equipment.
The resistor along with the voltage set the "range"
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 30th May 2023, 6:49 pm   #3
Jon_G4MDC
Jon_G4MDC's Avatar
Is that an attempt to meter Laser head lifetime?
Can't think what else...
Jon_G4MDC is online now
Old 30th May 2023, 8:04 pm   #4
ms660
ms660's Avatar
This early one also has one fitted (scroll down quite a way):
https://www.dutchaudioclassics.nl/ph...rototype_nr29/
Lawrence.
ms660 is offline
Old 30th May 2023, 8:44 pm   #5
geoff1234
Mike T
Many thanks for the confimation - But how is it supposed to be read? There is a marker some way along the internal column but no indication which is the zero end. Also, is there any information anywhere about the calibration of the device?
Old 30th May 2023, 9:29 pm   #6
Red to black
Red to black's Avatar
I have a feeling it wasn't intended to be read by the likes of us, more likely to have been calibrated within Philips themselves and only known by them how many hours have elapsed when it got to the end, Hitachi did similar with their early top loader Vcrs 8000/9000 series.
If you reverse the polarity to the component it counts down the other way
Red to black is offline
Old 30th May 2023, 9:35 pm   #7
Cobaltblue
Cobaltblue's Avatar
It's probably similar 120PC on this page
https://www.wiringdepot.com/Shared/S...ges/120-pc.pdf.
if we assume that its 4mA per hour and the supply is 5v that would give a full scale of approximately 570 hours the direction of movement is explained on the datasheet.
Doesn't sound a lot to me
We used the devices on military prototypes when I was just starting out.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 30th May 2023, 9:39 pm   #8
murphyv310
murphyv310's Avatar
Hi.
This was on SOME very early CD-100's that I found out later to monitor reliability. I'm pretty certain that select customers or perhaps Philips engineers or staff had these players. I have only ever come across one like this, (clearly remember it) many moons ago. There was a tie on label on the one I saw that said something like "only to be repaired by authorised Philips service agents" I never saw this on any other CD-100
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 31st May 2023, 6:34 am   #9
geoff1234
Mike T
Many thanks for that - now knowing its called a Coulometer makes finding information about it much easier. I will now be able to say for exactly how long my CD100 worked 40 years ago.
Old 1st Jun 2023, 8:18 pm   #10
Ed_Dinning
Hi Geoff, these were often of Curtis instruments manufacture and the central bead moved against the scale to denote elaplsed time. They can be reversed to reset
Ed
Ed_Dinning is offline
Old 2nd Jun 2023, 6:42 am   #11
geoff1234
Many thanks for that. In my CD100 the device is in series with a 750K resistor across the 5vdc line. What would the maximum hours on the scale be? My old brain cannot get its self around the mathmatics!
Old 2nd Jun 2023, 9:15 am   #12
Ed_Dinning
Hi Geoff, max hours depends on composition of the Hg salts that are used in the tube .It is effectively a plating and depleting process at very low currents.
Note that these were developed to measure battery life on the lunar rover
Ed
Old 2nd Jun 2023, 9:38 am   #13
Cobaltblue
Cobaltblue's Avatar
It depends upon the supply voltage and the type of device I loosely based my assumptions on the devices linked to in post #7 and assumed a 5V supply.
The devices are rate in mA/H for FSD
The device that I related to was the 120PC with a rating of 4.167mA for 1HR FSD.
So assuming the supply to be 5V and no (significant) volt drop across the device I=V/R so ~ 6.67uA.
4.167mA/6.67uA =625Hrs
But there are a lot of assumptions here
The way to be sure would be to take it out of circuit (having taken pictures etc) Reverse the current on an external 5V supply and measure the time it takes to retun to zero.
You know what percentage of FSD it is currently so you could then calculate the FSD current.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 2nd Jun 2023, 10:12 am   #14
wave solder
wave solder's Avatar
Another datasheet for the RS branded one here:-
https://assets.componentsense.com/im...6b8001a8fe.pdf
wave solder is offline
Old 2nd Jun 2023, 10:23 am   #15
Cobaltblue
Cobaltblue's Avatar
As 6.67uA would give 1000 hours with the device wave solder linked to thats a more likely match for the device being discussed here
Mike T
Mike T BVWS member.
www.cossor.co.uk
