14th Apr 2023, 7:00 am | #1 |
Vertical vs horizontal operation
A friend of mine asked me if there was any preferred orientation (vertical vs. horizontal) regarding his Revox B77. I can't remember ever hearing about any preference from a performance point of view, providing the machine is designed to operate in the required orientation - indeed, professional machines often seem to be mounted almost flat, at a slight angle, I'm thinking because it makes it easier to reach everything.
So I'll put the question up here - are there any reasons to operate a machine like the B77 in any specific orientation? |
14th Apr 2023, 7:29 am | #2 |
Re: Vertical vs horizontal operation
If there are feet on two surfaces, then the manufacturer is clearly enabling the machine to be used in either orientation. In theory I suppose one may offer greater longevity than the other, but not one that concerns the manufacturer. You're good to go on both.
14th Apr 2023, 9:30 am | #3 | |
Hope that makes sense.
-- Graham. G3ZVT Last edited by Graham G3ZVT; 14th Apr 2023 at 9:40 am. |
14th Apr 2023, 9:48 am | #4 |
Because of the use of three Papst outer-rotor motors, there isn't the easy way out of having a single-ball thrust support so there is no advantage to being flat on their back.
A nice slope will be fine. David
14th Apr 2023, 9:59 am | #5 |
On the odd occaision I have measured wow and flutter with a deck in both positions. The figure was always slightly better in the horizontal position. This was with decks that were designed to be used in either orientation.
Paul |
14th Apr 2023, 10:25 am | #6 |
I once read that Norman Leevers didn`t think it was possible to make a tape deck work optimally in the vertical position.
Having said that plenty of Leevers Rich tape machines were supplied for rack mounting. Vertical operation is a pain for editing of course but hardly anyone does that anymore, beyond sticking leaders on. |
14th Apr 2023, 10:49 am | #7 |
As Rambo1152 eludes, a thrust bearing on a horizontal deck's motor, relying on gravity and uniform centrifugal forces (such as a wrist-watch balance wheel) is easier to design, maintain and lubricate (thus longer lasting) than the far wider/larger weight supporting roller bearings on a horizontal shaft - for which additional end bearings are required.
Whether in reality it makes any significant or operational difference to a tape deck is another matter! |
14th Apr 2023, 12:13 pm | #8 | |
Speaking of viewing and cleaning the tape path, the A77 was a shocker. The B77 was improved but still not great. In both models visual style trumped functionality. The higher specced A700 and PR99 retained an "ugly but accessible" headblock. Reels have flown off a vertically oriented deck due to failure to lock the reel retainers. It can happen to anybody. With horizontal orientation, the reels should at least stay put from gravity alone. |
14th Apr 2023, 1:14 pm | #9 | |
[QUOTE=TIMTAPE;1551661]
I hated those machines. |
15th Apr 2023, 7:11 am | #10 |
The capstan of the Revox B77 has two domed washers ( items #6 in the picture) which apply preloading, l would expect this to remove any endfoat, whether in a vertical or horizontal position.
Regards, Ken. BVWS member |
15th Apr 2023, 10:29 am | #11 |
Hi Kentode,
in the diag given, the belville washers (6) shove against the Low Friction Washer (5). The Low Friction Washer shoves the collar (3) against the Sintered Bronze Bearing (Not Shown). The Thrust Bearing on the capstan shaft (4) is in the gap in the centre of the collar. There is some small endfloat. If there were no endfloat at all, the thrust bearing would be gripped and the resultant drag would play havoc with speed and Wow/Flutter figures. I personally prefer the vertical position as the reel motor bearings will the have radial forces to deal with. If the machine is horizontal the weight of the reel will be an axial force which the roller bearings will not be as hardy. All a matter of opinion/taste of course. Alphonse01 |
15th Apr 2023, 10:52 am | #12 |
Thank you, Alphonse for the explanation of the other components in the capstan motor, that makes sense.
The B77 comes with feet on the back and base, so presumably Revox considered it was capable of operating in both directions.
