9th Feb 2019, 9:01 pm | #21 | |||
Re: Wima 'Toffee' Capacitors
Another problem was one that was located next to a dropper resistor for the Zener powering the board, it would cause that quarter of that circuit to drift out of calibration with the heat. The problems were very rare though, many are still in service in trains at the moment and probably will be till the trains are eventually withdrawn from service & replaced. Now that I no longer repair electronics for a living I was able to buy the components that were to be binned with the closure of the department, so I now have many NOS WIMA yellow capacitors for use in my own repairs, most are lower voltage ones though. David |
9th Feb 2019, 9:44 pm | #22 | |
Why go to the hassle?? When yellow MKT-caps are available for pennies?? If you're faced with suspect components [either in-circuit or in your spares-racks] it only ever makes sense to replace them with currently-most-reliable-technology parts. Good-quality, reliable parts are dirt-cheap these days. Your time is expensive! |
10th Feb 2019, 4:51 pm | #23 |
I'm not sure about that. I have seen plenty of Plesseal types with badly cracked encapsulaton - including some where it has fallen off completely, leaving just the capacitor winding.
10th Feb 2019, 4:52 pm | #24 |
EMI 201 vidicon cameras https://www.tvcameramuseum.org/emi/201/201p1.htm used large numbers of dark toffee coloured Wima capacitors. The encapsulating resin of these developed severe cracking often causing the resin to fall off leaving the wound foil exposed. I don't know how many types were involved, nor can I remember the foil material. I also seem to remember a fungus like discolouring along the cracks which made them look diseased, not at all pleasant.
Kits were issued for their wholesale replacement in the camera head, CCU and power supply but I don't know if these kits came from EMI or the BBC Equipment Department. It must have cost someone a lot of money, possibly WIMA or the resin supplier, even if only through damage to their reputation. PMM |
10th Feb 2019, 5:18 pm | #25 |
Is it these that are found in the large, high quality Grundig late 50s radios? I remember changing a load of them last time I restored a model 3028, but I don't recall the brand?
10th Feb 2019, 6:19 pm | #26 |
Yes, Grundig used these in the late 50’s early 60’s.
Frank |
