24th Sep 2018, 6:16 pm | #21 | |
Re: Transformer safety?
PME (earth and neutral connected at the incoming mains point) is considered very unlikely to go wrong with moderate dangers if it did. |
24th Sep 2018, 8:06 pm | #22 |
Some time back Chas Miller did an article in which he described how to isolate the neutral return from chassis by creating a bus bar. The chassis is connected to the bus bar using Class Y capacitors as normally you cannot isolate all components such as the tuning capacitor frame from the chassis. The same principle could be used for a set with an auto transformer. The article was published in Radiophile of course and someone will probably remember which issue. It sounds a bit complicated but for many sets it probably isn't. Many American sets were built like that in the first place.
24th Sep 2018, 8:12 pm | #23 |
Always best to check on a live chassis that the insulation is all there as intended. It only takes a loose neutral in your mains plug or multiway adapter for the chassis to lose it's reassuring tie to neutral, or indeed to turn the set off if the single pole mains switch is in the neutral, for metalwork to be hazardous to touch.
Kevin |
24th Sep 2018, 9:05 pm | #24 |
Another vote for the Cossor here. Great under appreciated sets. Good sound and no tuning drift on VHF.
Paul |
25th Sep 2018, 4:59 am | #25 | ||||
That aside, if AC/DC (and autotransformer AC) equipment really was much safer than the AC-type with isolating transformers, why did the UK educational authorities generally insist that only radio/TV/audio equipment fitted with mains isolating transformers be used in schools? Cheers, |
25th Sep 2018, 8:00 am | #26 |
I don’t have a problem with receivers with an isolated mains transformer being considered safer than live chassis sets, it’s the age of the transformer in these 50+ year old sets that is being relied upon for safety that’s the problem for me.
Perhaps I am being over cautious but I am happy to use this equipment knowing it’s potential problems, but I wouldn’t give a set to anyone who wasn’t aware. I use RCD’s and lightly fuse the sets I have.
Frank |
25th Sep 2018, 10:01 am | #27 |
I would have thought that many 50+ year old sets would not meet current “double insulated” standards, whether live chassis or not.
With a live chassis set, you need to look at and possibly modify aerial and earth connections, gram inputs where fitted, and some sets even had speaker outputs using the output transformer for mains isolation. Then there are sets such as the DAC90 where it is difficult to ensure that the chassis is always connected to neutral. For a set with an isolation transformer, fitting a 3-core mains lead and fused plug should protect from failure of the transformer (or the wiring to the on/off switch etc). In truth of course, we don’t necessarily choose our favourite sets by their chassis isolation, but I think it’s easier to improve the safety of a set with a double wound mains transformer than one with a live chassis. Stuart |
25th Sep 2018, 11:31 am | #28 | |
The Murphy A362 is a live chassis AC only set as has been said. The later A372 is identical in most respects.
The knobs are pull off types but there is an insulating sleeve over the control shafts that cannot be removed while the chassis is in the cabinet. |
25th Sep 2018, 11:40 am | #29 |
There's also the Ext. LS connection to mains earth.
Lawrence. |
25th Sep 2018, 5:13 pm | #30 |
..and that would be a safety earth of course.
25th Sep 2018, 11:07 pm | #31 |
There is certainly a case to be made that a mains-common chassis doesn't try to lull you into a false sense of security; you know it's not supposed to be safe to touch, and it is insulated accordingly. A set fed from a proper mains transformer by a 2-core lead with no connection to Earth is usually safe to touch anywhere with one hand, by virtue of this lack of a return path; but there will be no tripping of RCDs or blowing of fuses if a transformer-fed set develops an unwanted Earth connection, which would then render the set unsafe to touch.
Of course, there's also a case to be made that you shouldn't be treating anything as "safe to touch", at least not until you have tested it with something a bit more sophisticated than the old neon screwdriver. I reckon an autotransformer is really the worst of all possible worlds. On first glance, it looks like a transformer, but does not actually provide isolation; while it also cannot be used on a DC supply. And an autotransformer can't really have offered much cost saving over a proper isolating transformer anyway .....
25th Sep 2018, 11:18 pm | #32 |
I don't know- a proper isolating transformer with HT and LT windings would need to be about 50VA rated whereas a heater only auto needs only to be about 20VA rated for a typical 4 or 5 + R set.
25th Sep 2018, 11:33 pm | #33 |
I don't think the un-earthed construction of transformer sets would have been cavalier at the time, they weren't meant to be held or transported while in use (unlike say a power tool, which were some of the first appliances to include an earth wire). The earth terminal was supposed to be earthed 'somehow' albeit for signal purposes, whether onto a water or gas pipe, nearby radiator or one of those chemical earths you were supposed to keep watered. Even pre-war sets would've been flash-tested on the production line several times before despatch. There's a video or two on youtube showing a uk radio factory production line in the 30's.
Since transformers insulated with paper and wax could suffer leakage 60 years on, I usually earth mine with a new 3-core flex, since we have the luxury of earthed mains sockets. Such sets of course will also have protruding chassis bolts, an external aerial wire and generally less care to prevent contact with the chassis. That said, I've never had one leak to earth, but there's always a first time.
Kevin |
25th Sep 2018, 11:36 pm | #34 |
Plus the heater-only autotransformer would have its cost slightly offset by the omission of a usually fairly hefty dropper section, and design eased by less heat production. There would still be an HT surge limiter section but as off-line rectified HT sets usually needed all the volts they could get for decent audio power in particular, that dropper section would be small. Makes scale bulb powering less of a knotty gamble of surge-limiting versus running brightness than with series-feed sets, too!
Crossed with McM. |
26th Sep 2018, 11:42 am | #35 |
The discussions here seem to have ignored both fault and power off conditions.
Many AC/DC sets use a single pole switch to chassis that leaves the chassis live when switched off. Even if you have a double pole switch, a fault in the switch (very common) can leave the chassis live. Then there is the risk from a connection breaking in the mains cable giving a 50% chance of a live chassis. |
26th Sep 2018, 1:09 pm | #36 | |
And if the heaters are in series, then the autotransformer can be rated even less - such as the Bush DAC90a. Heater volts 116.6V at 0.1A. Operating from 240V (so losing 123.4V), the 100mA appears as 48.58mA flowing in the 116.6V winding and 51.42mA in the 123.4V winding. So the autotransformer is the size of a 5.66VA rated double-wound transformer, so can be tiny. There is one aspect which hasn't been considered with respect to safety - and that's failure! Transformers often fail with a shorted turn or turns, getting hot, smoking, catching fire even if wax impregnated (which they often are), without drawing enough current to blow a fuse. Dropper resistors, on the other hand, when they get old, just go open so they are fail-safe. If you want to leave a radio running unattended, make sure it's an AC/DC one! |
26th Sep 2018, 1:32 pm | #37 | |
26th Sep 2018, 1:38 pm | #38 |
You shouldn’t leave old technology running unattended Live chassis or isolated, that’s my opinion, appreciate it’s not everyone’s.
Frank |
26th Sep 2018, 9:56 pm | #39 | |
Some years ago, a friend, who is very conversant with old tech, had left a 1950's woody radio on downstairs in the kitchen. He had been using it for some years and it had never given any problems. He had been upstairs for several hours when he became aware of a strange smell. Going to the top of the stairs, he could see a wall of smoke. Taking a deep breath, he plunged down in to the kitchen, to find the radio pouring acrid smoke! The mains transformer had developed shorted turns and overheated. Fuses are usually no use in this case . So failures do occur with old transformers! I would not leave any old tech, whether it was live chassis or transformer, operating unattended. I'm not sure how happy I'd be giving any old mains tech to someone who I was not confident was experienced enough to understand the hazards. We, as repairers, have the responsibility to ensure any items used by other people are as safe as reasonably practical. A case in point was recently a friend gave me a 1920's art deco heater he had bought."Can you fit a new mains lead"? I declined on the basis that there was minimal guarding to the exposed element and no mains switch. I assessed the shock hazard as being unacceptable. He would have used it without any worries as he, like most untrained people, is not competent to assess the dangers. All the best Nick Last edited by 1100 man; 26th Sep 2018 at 10:14 pm. Reason: more text added |
26th Sep 2018, 10:16 pm | #40 | |
I have no problems with running my RCA AR88D, a couple of Pye PCR receivers, a 'Collins" TCS [though outsourced to be built by Stewart-Warner] a RACAL RA217/MA323 or various Eddystone/Roberts/Bush gear (let's not mention the Barker-88) continuously and unattended. My experience has been that a lot of 'stuff' fails when switched-on or switched-off; if you can avoid these surges it'll live a lot longer. Keeping stuff warmly powered-on also avoids damp-ingress (which leads to the dreaded greenspot corrosion of coils] and reduces oscillator-drift [I truly hate chasing SSB stations across hundreds of Hertz as a free-running local-oscillator settles-down from a cold start]. |
