Old 16th Feb 2020, 9:31 am   #1
clacker
Default Pye Black Box with BSR deck - disconnected spring
Hello, I was given a Pye Black Box a few years ago that I've used fairly often. During a failed attempt to change the stylus (which fell into the case) and subsequent lifting of the BSR deck, I must have knocked a spring free of one connection. The turntable plays fine until reaching the end of the record when the tonearm lifts and moves back to the start of the record. I see on the underside of the deck that a spring is free - but there isn't an obvious place to set the free end.
Would this spring be cause of my problem, and if so where should the spring be set?
Any advice appreciated!
ID:	199053   Click image for larger version
clacker is offline
Old 16th Feb 2020, 11:16 am   #2
Michael Maurice
Michael Maurice's Avatar
Default Re: Pye Black Box with BSR deck - disconnected spring
I'll have to post a photo later, but if you turn the deck upside down, you'll see the main plate that slides on the top of the sub chassis has a protrusion that goes below the sub chassis. The spring hooks onto that.
Forum Moderator
Michael Maurice is offline
Old 16th Feb 2020, 12:30 pm   #3
John10b
Hope this helps.
John
John10b is offline
Old 17th Feb 2020, 8:19 am   #4
clacker
Thanks, yes I think that's done the trick!
clacker is offline
