Old 12th Oct 2019, 10:01 pm   #1
henrymarpla
Default Remove metal plate that covers knobs
I need help how to remove metal plate that covers knobs (tuning and volume), under which is screw to remove knob, they are glued, and I do not want to bend it or damage it, a photo of the radio. Thank you very much for any input.
ID:	191803   Click image for larger version
henrymarpla is offline
Old 12th Oct 2019, 10:32 pm   #2
Boulevardier
Default Re: Remove metal plate that covers knobs
How do you know that the plates are glued on? The knobs are more likely to be be push-fit than held on by screws. Have you tried (very gently) pulling the knobs off? You may need to try (very, very gently) levering them off if they are really tight.
Mike
Boulevardier is offline
Old 12th Oct 2019, 10:45 pm   #3
henrymarpla
I have two radios of this type, one with these plates and another that have removed them .... Yes, retaining screws are underneath....
Old 13th Oct 2019, 9:45 am   #4
Tractionist
Hmmm ..... the front/face of the knobs seems to be bigger than any hole[s] in the plate i.e. holes that their screwed shafts apparently go through. Therefore, irrespective of the fact that the plate may be glued-on - the knobs must be removed first i.e. prior to removal of the plate.
Ergo - you must access the rear of the plate in order to access and release the screws retaining the knobs. This will probably involve removal of the interior lining of the case etc. (The latter is likely to be glued-in too .... so great care will be required - possibly involving soaking with a benign solvent, or even steam.)
P.S. It looks as though a similar process will be required [i.e. removal of the case lining] in order to remove the speaker and clock too ....
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 13th Oct 2019, 9:48 am   #5
leslie5555
If they are glued in place then maybe heating with a hair dryer will soften the glue enough for them to be gently prised out.
leslie5555 is offline
Old 13th Oct 2019, 11:37 am   #6
Dickie
Is it possible the OP means removal of the knob "brights" in order to gain access to axial screws that secure the knob to the control shaft?
A picture of the dismantled one would help.
Regards,
Richard, BVWS member
Dickie is offline
Old 13th Oct 2019, 11:48 am   #7
G6Tanuki
G6Tanuki's Avatar
That's what I am assuming: I guess the tuning capacitor is a 'polyvaricon' type - these often have a hole down the end of the (very short) tuning-spindle to retain the knob.
To remove - you've got to remove the metal disc - as suggested, warming with a hot-air-gub/hairdryer may soften whatever glue is used to hold the metal plate to the centre of the knob.
G6Tanuki is offline
Old 13th Oct 2019, 11:49 am   #8
ms660
ms660's Avatar
The shafts usually have two flats and a screw hole down their ends.
EDIT: Post crossed.
Lawrence.
ms660 is offline
Old 13th Oct 2019, 5:10 pm   #9
poppydog
I had to do a similar thing to a small far eastern transistor radio from late 60s early 70s, and I ended up using a heat gun with a little ipa to soften (what I think is contact adhesive) and a soldering aid hook to get underneath the aluminium disc. I used tin foil to protect other parts of the radio from the heat gun. Care will have to be taken that the ipa doesn't take the print off the disc and you don't distort the aluminium disc with the hook..
regards poppydog
poppydog is offline
Old 13th Oct 2019, 5:11 pm   #10
henrymarpla
Mr. Dickie, a picture of the dismantled.
Old 16th Oct 2019, 8:51 pm   #11
henrymarpla
Any idea how the aluminum sheet comes off.....Thank
Old 16th Oct 2019, 9:02 pm   #12
Jolly 7
Is the aluminium plate glued on to the leatherette material or does it have small hooks at the back that can be lifted up, for example with a small flat screwdriver ?
Jolly 7 is offline
Old 17th Oct 2019, 12:02 am   #13
henrymarpla
I need help how to remove metal plate that covers knobs....
Old 17th Oct 2019, 12:37 am   #14
Lloyd 1985
Lloyd 1985's Avatar
The only thing I can think of that would be thin enough to get into the gap between the knob and the aluminium disc would be a scalpel blade, give it a bit of heat from a hot air gun then very gently try lifting it with the blade, it’s going to be very difficult to remove it without damage, and also not to stab your fingers with the blade!
Regards
Lloyd
Lloyd 1985 is offline
Old 17th Oct 2019, 6:18 pm   #15
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
It appears to me that the re-assembly will be a bit of a tricky job, too. The aluminium plate, once removed, will need to be re-aligned to the index arrow for correct tuning, won't it?
Colin.
ColinTheAmpMan1 is offline
Old 17th Oct 2019, 9:24 pm   #16
henrymarpla
Mr. ColinTheAmpMan1, look at the small hole, where you read X1OOKC, to align.
Old 18th Oct 2019, 3:31 pm   #17
ColinTheAmpMan1
I was hoping there might be something like that. Good.
Colin.
Old 18th Oct 2019, 4:02 pm   #18
Goldieoldie
Put some lighter fluid on the disk.Its good for softening the glue
If you can lift the disk slightly to let the fluid in would be good
If that fails then
If you can protect the disk with some foil Useing a hot soldering iron on the disk can help
Cheers Pete
Goldieoldie is offline
Old 18th Oct 2019, 6:31 pm   #19
Brian4radio
Brian4radio's Avatar
Hi Henry, well if it was my problem, and the knob has got to come off, I would drill a small hole down the centre of the knob squirt some WD 40 down towards the centre of the screw and just undo the Philips screw. If you start using solvents or heat prying tools you have a chance of destroying the total knob structure. If and when the knob has to be reinstalled you could "glue" a bead of aluminium over the drilled hole and a man on a galloping horse would never notice it, Ha Ha .In fact it will then be a unique radio regards Brian.
Brian4radio is offline
Old 18th Oct 2019, 8:47 pm   #20
60 oldjohn
Years ago if they had to removed it would have been ripped off and new metal plate bought. Today its much more difficult and time consuming.
Could you put it in a plastic bag, placed in the freezer, hopefully making the glue brittle. After 24 hours work knob between finger and thumb. The knob brights are often missing due to the glue deteriorating with age. Personally I would not risk using heat, Its so easy to do damage to the set.
John.
60 oldjohn is offline
