Old 16th Jul 2019, 11:04 pm   #1
Mandrex
Smile Hammond clock power cord replacement help needed
Hello all,
I won a very nice large square Hammond clock in an auction.
The power cord has been cut due to fraying and possibly aluminum wires and i'd like to place it.
I would greatly appreciate the help in removing the SET knob properly.
Many thanks in advance!
Henry
ID:	186825   Click image for larger version
ID:	186826   Click image for larger version
Mandrex is offline
Old 19th Jul 2019, 3:05 am   #2
usradcoll1
Default Re: Hammond clock power cord replacement help needed
First, I would connect a power cord to the cut end to see if the clock runs and keeps time.
It's kind of hard to see if there's enough room to get a needle-nose pliers under the set knob to remove it. It probably has a right hand thread, so turning it counter clockwise, while holding the shaft, if it could be held with the pliers. Other than that, it's anyone one's guess.
Hammond clocks didn't survive like some of the others, so they're a bit rare.
Dave, Midwest USA.
usradcoll1 is offline
Old 19th Jul 2019, 3:39 am   #3
Mandrex
Thanks Dave; there is enough room. I can be heavy-handed at times so any specific help is appreciated!
I will "give it a whirl!"
Mandrex is offline
Old 19th Jul 2019, 10:04 am   #4
jez_145
Hi Mandrex,
In the case of my Hammond clock, the setting knob was simply a (tight) push fit and I removed it by placing a small piece of thin plywood over the cover, to spread the load, and then used a knife to lever the knob from the spindle. There was certainly no screw thread but your mileage may vary.
Full story here:-
https://www.vintage-radio.net/forum/...d.php?p=766844
Jerry
jez_145 is offline
Old 23rd Jul 2019, 2:09 am   #5
Mandrex
Smile Re: Hammond clock power cord replacement help needed
Dave, Midwest USA.
And, in the words of Ed McMahon: "You are correct sir!"
The small needle nose and the left twist; with some authority, off with the knob!
Investigation of the cord revealed nice copper wiring but wrapped in two layers of fabric... hence the fire hazard.
Located a replacement cord but not yet tested....
Thank you all for your excellent assistance!!
When i test it (soon...) i will check back with you.
Mandrex is offline
