Old 28th Sep 2010, 11:19 am   #1
Mike Brett
Default wiring transformers
Hi all
Simple question, I have a 240 volt transformer with two sets of outputs, 0-18v and 0-18v. How do I connect the four terminals to get 36 volts. Do I join the middle two connectors 0v and 18v together and use the two outer 0v and 18v for the 36 v output.
Cheers Mike
Mike Brett is offline
Old 28th Sep 2010, 11:34 am   #2
G8HQP Dave
Default Re: wiring transformers
Assuming the tags are in winding order, then yes. Check with an AC voltmeter - if you are right you get 36V, if wrong more or less no volts. Provided you only make one connection between the two secondaries you won't do any harm either way.
G8HQP Dave is offline
Old 28th Sep 2010, 1:42 pm   #3
Mike Brett
Hi Dave
Yes that works ok, thought it best to check.
Cheers Mike
