Old 4th Sep 2019, 6:03 pm   #1
Puffie40
Default Megger Major Insulation tester
I picked up a Megger Major from a retiring small-time electrican. It is a 1000 volt, hand crank insulation tester, and is in pretty good cosmetic shape for its age.
From using it, I have observed The needle goes past zero ohms and not quite to infinity ohms, which, from what I gather from threads here, is a fairly common issue. Is there a capacitor inside this model I should consider replacing? I am reluctant to break the lead seals to get inside.
Is there a copy of the manual someone would like to share?
Thanks!
Chris
Puffie40 is offline
Old 5th Sep 2019, 8:43 pm   #2
Barnmead
Barnmead's Avatar
Default Re: Megger Major Insulation tester
Have a look at the Biddle site. The American version of the Major Megger is cat 21159. Perhaps not identical but the description and fault finding could be helpful.
Richard
Barnmead is offline
