30th Oct 2019, 2:45 pm | #1 |
Help with 1950's Bush record player.
With my ongoing loft sort-out I came across this record player.
It's been up there for well over 20 years and to honest I'd forgotten about it. I plugged it in and it actually works, been playing 78's and they sound really good. The amplifier seemed to working fine but I have a problem with the rubber wheel that drives the platter. (see double picture) It wasn't left in the 'off' position (my fault) so the wheel has a indentation from it being pressing against the drive shaft for countless years. So it's rather noisy in operation, I suspect the rubber has hardened anyway over the years. My question is, are these wheels still available? or is there any other way to improve matters, I would be rather nice to get this player working better as it's rather a nice thing. Thanks.
Clive |
30th Oct 2019, 3:12 pm | #2 |
Re: Help with 1950's Bush record player.
I have a 'donor' Garrard deck from the same era - I think it still has an idler wheel - I'll check it for dents and pop it in the post if you like. Send me a PM.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
30th Oct 2019, 6:37 pm | #3 |
I've read somewhere on this forum that boiling can sometimes improve matters by softening the rubber. (It'll make the spuds taste funny, though. ) Otherwise, they can be gently sanded to remove the flat spot as its diameter isn't important to the speed of the turntable. Hope this is useful Cheers, Pete.
30th Oct 2019, 7:14 pm | #4 | |
"I really am seriously downsizing " |
30th Oct 2019, 7:33 pm | #5 |
MurphyNut, the rubber wheel you mention is more usually known as the Idler wheel. These can be skimmed on a metal machinist's or a wood turner's lathe. Only a few microns will need to be removed and it will only cost you the price of a pint! It will then be as good as when new.
I can see that the tone arm still has the original Mono only cartridge in-situ, so do not attempt to play any Stereo LP's on this. Your player has a 2 stage amplifier which is suitable for a new Stereo ceramic cartridge should you decide to upgrade it.
Edward. |
30th Oct 2019, 10:36 pm | #6 |
I'm lucky if I can work to 0.01mm or half a thou!
31st Oct 2019, 5:04 pm | #7 |
Thanks to the suggestions I've got it working a lot better, I put the Idler wheel into hot (almost boiling) water for a while and it did soften the rubber quite a bit.
I gently sanded out the dent and now there is a lot less physical noise. Unfortunately there is another problem, I'll post up a new thread regarding this later. Thanks again
Clive |
31st Oct 2019, 6:06 pm | #8 |
