20th Oct 2019, 11:42 am | #21 | |
Re: Leak TL10 power supply modification
An AVO 8 on its 500V range is as good as a decent DMM for checking HT level voltages as far as loading goes. (It may not be as accurate or precise.)
20th Oct 2019, 11:56 am | #22 |
Thanks again Alan. I keep forgetting to get out the Avo.
It looks like the noise is coming from the EF86 area, which still has mostly original components. The internal speaker connections are original, as you describe. When pairing the amp to test with another mono Heathkit MA12, I found that the phase needed to be changed. I’m going to move on with tidying up the wiring, trying cable lacing for the first time, and first wondering how to repaint the chassis, which has deepish scratches on top and some corrosion at the back. Looking around B&Q and Halfords I haven’t yet found the right colour. |
20th Oct 2019, 12:41 pm | #23 |
Thanks Chris. I didn't see your post while replying on my phone. I have an AVO 8 and need to keep it in sight!
20th Oct 2019, 4:49 pm | #24 |
Here is an oldish thread which mentions the same Leak amp bring used in a Bal Ami jukebox: https://www.vintage-radio.net/forum/...ad.php?t=27749
20th Oct 2019, 9:36 pm | #25 |
Hi Qualityten,
Thanks for the link to the other TL10 thread on the forum. When I restored my TL10’s I used two separate cathode resistors – it made sense as I had to replace the resistor(s) and capacitor(s) anyway. Regards the speaker terminal I could take a picture of the wiring of speaker terminals on one of my TL10’s. I use the 8 Ohm tap with modern speakers. Finally, it looks as if the TL12.1 could be an early juke box amplifier, but I suppose I’ll never know for sure. I did ask an engineer friend who worked for Leak in the early to mid-60’s and he couldn’t help either. He told me stories of TL12.1’s in the Pirelli Tyre factory PA system and TL25+’s in Abbey Road, but couldn’t identify my TL12.1 Regards Terry |
21st Oct 2019, 8:04 am | #26 |
Looking more closely at my unit, I think that the holes are an aftermarket modification, but done for Bal Ami. The original 117V transformer suggests the jukebox was originally used in the US.
The way they crammed the volume control, preamp and tone controls into the tiny space where one octal socket was is amazing. Ironically, I think the amp may have been set aside. because the RCA input socket broke. If only these old amplifiers could tell their own stories. |
21st Oct 2019, 9:16 am | #27 |
Where Terry's TL12 was clearly drilled 'after' manufacture, I wonder if your chassis has paint or signs of paint inside the extra holes? That might indicate it was made for the purpose. (As has been mentioned, Leak made amplifiers for different markets and the chassis were usually manufactured to suit.)
You would best take it to a motor respray firm to match the colour. I am not aware of anything off the shelf that comes close to the original gold paint. I am not up on jukeboxes, but aren't a lot of them or the mechanisms, 117 volts even in the UK? Alan
22nd Oct 2019, 1:02 pm | #28 |
Alan, looking at the chassis in artificial light last night suggests that the holes on mine were drilled after manufacture. I'll have a look in daylight (when me and the chassis next meet in the daylight!) and double check.
I have no first hand knowledge of jukeboxes at all.... |
22nd Oct 2019, 1:24 pm | #29 | |
22nd Oct 2019, 7:28 pm | #30 |
Thank you for the steer David!
10th Dec 2019, 4:08 pm | #31 |
I've finished my restoration of this amplifer. I used gold hammerite paint, so I'm not sure whether it may be considered sympathetically done or not! Wood Auto Factors were unable to supply matched paint with a posted sample.
I have one further request of any forum member who owns a TL/10: please can you help me with the physical grounding locations. As I received this amplifier with a non-standard power transformer, the wiring loom had already been disturbed. In wiring it up, with some replacement wire, I have ended up with one additional black ground wire, and a very soft hum. With the thick Hammerite paint, I only have the chassis grounded at a chassis point between the input RCA socket and the EF86, with a connection going underneath the tag-board from there to the first of the four filter capacitors. So, if anyone with a TL/10 could describe for me the 'as original' grounding points, that would be very helpful. Thanks. |
7th Feb 2020, 7:01 pm | #32 |
Revisiting this build, I noticed that there are two different values given in different places for the coupling capacitors C7 and C11.
Please can I have advice on this. Should they be 0.1uF (as per the nice clear circuilt published by the Australian Radiotronics journal, Vol 20 Dec 1955, No 12), or 0.04uF, as per the more common circuit, also found on the 44bx.com Leak website? And, is the difference likely to be audible either way? I'd also be interested to hear any others' experience of replacing the original carbon composition resistors with metal film ones. I know it's a well-trodden subject, but I found replacing them with cheap Chinese metal film ones made the amplifier sound a bit brighter/harsher. |
7th Feb 2020, 8:18 pm | #33 | |
Not sure I have noticed such a marked difference with MF vs carbon resistors. Though they are a little brighter. I always use metal film to the anodes to keep noise down. Interesting to hear other opinions.
7th Feb 2020, 10:41 pm | #34 |
Old carbon composition resistors drift in value, are intrinsically noisy and crackle and pop so there is no knowing how they might be behaving, so any audible differences after replacing resistors is likely to be because the new metal film resistors are working as the designer intended.
7th Feb 2020, 11:18 pm | #35 |
Thanks, Alan and PJL, for your replies. Was Leak known for modifying circuits? The H H Scott amplifiers from the USA are often confusing because of circuit variations for the same model number.
