3rd Apr 2019, 7:13 pm | #1 |
Back to the future
Has anyone on this forum tried building a modern version of Clive Sinclair's X10 D class audio amp using silicon transistors (not supposedly rumoured reject germanium ones like the original). I have decided to have a go just to see if I can get it to work. 40 kHz square wave generator, integrator and audio pre amp using BC549, output stage using TIP31 and TIP32 output tranies.
3rd Apr 2019, 7:33 pm | #2 |
Re: Back to the future
No. But I'd be interested to hear of results!
The circuit looks as though it would work, but not work well. I like simple stuff, but this looks TOO simple for what it needs to do. |
3rd Apr 2019, 7:59 pm | #3 |
This was actually designed for uncle Clive by my old friend Gordon Edge. Actually Gordon's version was rather better than Sinclair eventually marketed. The final one that was sold had no output filter - it relied on the voice coil inductance of the speaker to do the filtering. Apparently caused mayhem with radio reception.
Unfortunately Gordon is no longer with us, so I can't ask him for any more background. It was famed for lack of reliability, over-hyped power specs that it could not meet - so basically meat and two veg for Sinclair at that point. Other Sinclair background. I bought a Sinclair Scientific calculator when it was first introduced. Suppose I must have been 17 or so. It had a wonderful quirk - if you asked it to do something like find the inverse sine of something greater than 1 (which has a complex solution) it gamely tried to do it, with the display flashing fitfully for a few minutes - and then gave a result, which was of course completely spurious. And the QL had a similar quirk. The designers has put common constants and things that were done frequently by a programme writer in a look-up table. One of those was root 2. Except they had put in the wrong value into the ROM. So you got a tantalizing close answer, but subtly wrong. If you asked to find the root of 2.0001 it had to actually calculate the value - which it got right. All wonderful in the world of Sinclair. The man who used tons of dud transistors as hard core underneath his drive. Allegedly. Craig |
3rd Apr 2019, 8:33 pm | #4 |
As noted, the original X10 with its lack of output-LPF would cause horrible interference to LW/MW radios.
(like many of Uncle Clive's offerings, there was probably more money spent on the advertising than on the technical design. I had a Sinclair "Black Watch" as a student; it went crazy every time I used one of the lab's 450MHz Pye PF70 walkie-talkie)] |
3rd Apr 2019, 9:03 pm | #5 |
I recall my X10 class D amplifier: in fact I'm sure that I still have it somewhere safely stored in a junk box. It worked tolerably well into a single 12-inch speaker, but quickly released its magic smoke when I connected it to a more sophisticated 2-way speaker with crossover: it just couldn't handle a complex impedance load.
Like so many Sinclair designs, it was a primitive premature application of an interesting innovative idea. It was way ahead of its time because of course, most consumer amplifiers are now class D. ISTR that I modified my X10 to have a much lower sample rate, and hence very restricted bandwidth. It was then little more than an illustration of the Class D principle, but interesting nevertheless. Martin
BVWS Member |
3rd Apr 2019, 10:59 pm | #6 |
Does anyone remember the early Sinclare basic calculator that used to count for ever if you divided 1 by zero?
They were in the shops in the mid 1970s. |
3rd Apr 2019, 11:13 pm | #7 |
The Scientific. Like I said in post #3
Craig |
3rd Apr 2019, 11:16 pm | #8 |
I am pretty sure it was a basic 4 function one.
3rd Apr 2019, 11:28 pm | #9 |
I must admit I'm surprised that there were so many Sinclair calculators! Google being your friend....
http://www.vintagecalculators.com/html/sinclair1.html Last edited by Craig Sawyers; 3rd Apr 2019 at 11:36 pm. |
3rd Apr 2019, 11:36 pm | #10 |
I think it was a white one but not scientific.
It might have been a universal. I was once given one with a broken case and the board used to do the same thing. |
4th Apr 2019, 9:14 am | #11 |
Martin had me laughing, and gave me the idea of making a jocular remark about Clive suffering from premature application, but it was his customers who did the suffering.
He missed out on making his C5 autonomous. David
