4th Feb 2019, 12:28 pm | #1 |
Grundig Mandello no power
Hi Guys
Hopefully someone can help I have a grundig mandello and I was using it this morning before I took my daughter to school I've come back and now it won't turn on it doesn't matter which switch you press nothing happens so I took out the chassis a sprayed the switching mechanism with wd40 contact cleaner and it's made no difference apart from making the vhf button stick any ideas what to do Thanks Stephen |
4th Feb 2019, 12:35 pm | #2 |
Re: Grundig Mandello no power
I assume you've checked the fuse in the plug, assuming that plugs in Jersey have fuses, and any internal fuses within the unit?
4th Feb 2019, 12:56 pm | #3 |
Link to circuit in this thread:-
https://www.vintage-radio.net/forum/...d.php?t=118110 It'll blow up quite nicely if you save it. ---- Do the valves light up? If you have a meter measure the resistance between the LIVE and NEUTRAL pins of the mains plug. With the player unplugged and switched ON of course!
4th Feb 2019, 1:06 pm | #4 |
The plug is fine as it has a red light on the plug which is lit I am trying to find someone who sells the 1amp mains fuse over here but not having much luck does the fuse going normally happen after you turn it off
4th Feb 2019, 1:18 pm | #5 |
Fuses normally blow at the instant a set is switched on or while a set is switched on.
I assume the 1A fuse is an internal one? Have you checked it visually or with a meter? Fuses sometimes get tired and let go, but it's possible there's a fault which has caused a fuse to blow. Do the valves light up?
4th Feb 2019, 1:23 pm | #6 |
Nothing happens when you press the buttons the radio back light the turntable it's all dead
4th Feb 2019, 1:33 pm | #7 |
The fact the turntable doesn't work points to a fault with a fuse, the voltage selector or the mains switch.
The easiest of these to check and replace are the fuses. Do you have a meter?
4th Feb 2019, 1:48 pm | #8 |
If it is for the 13A mains supply plug, you can use a 2A or 3 A fuse, not essential to have a 1A.
Not quite sure when you say there is a "red light on the plug", do you mean the socket?
Edward. |
4th Feb 2019, 2:31 pm | #9 |
4th Feb 2019, 2:33 pm | #10 |
4th Feb 2019, 2:37 pm | #11 |
The trouble is that we don't know whether the red light, probably a neon, is wired in before or after the fuse.
Remove the plug fuse and plug it in to the mains. If the light no longer lights the fuse is OK.
4th Feb 2019, 5:17 pm | #12 |
I have now replaced the plug fuse and no difference so I guessing the mains fuse would be next which I've had to buy from eBay because normal plug fuses are to big hopefully that will fix it otherwise I have no idea what to do next and I really don't want to part with my radiogram
4th Feb 2019, 5:31 pm | #13 |
Still, er, conFused....
If you have replaced the fuse in the mains plug, what do you mean by a "mains fuse"? Do you mean an internal fuse on the actual internal metal receiver chassis? I doubt whether there is much, or anything, wrong with your Radiogram, so don't worry.
Edward. |
4th Feb 2019, 5:47 pm | #14 |
Looking at the diagram there is a 0.4A slow blow internal fuse in series with the mains supply. That's for a 230V mains supply which I assume is what you have in Jersey?
If it's a glass fuse a visual inspection should show whether it's intact or not.
4th Feb 2019, 6:12 pm | #15 |
Just to note, there are several versions of the Mandello, some S.S. some valve.
Lawrence. |
4th Feb 2019, 6:16 pm | #16 |
Indeed. My question "Do the valves light up?" got no specific response.
4th Feb 2019, 6:23 pm | #17 |
The S.S. version has a 1 amp fuse in the B+ side of the bridge rectifier not that that's conclusive.
All will be revealed no doubt. Lawrence. |
4th Feb 2019, 7:00 pm | #18 |
If it is the same Mandello with the FM problem, it is valve. (https://www.vintage-radio.net/forum/...light=Mandello)
It needs to be a 0.4A T (slow blow)... Alan
4th Feb 2019, 8:06 pm | #19 |
Hi Guys it seems I need to clear some things up my apologies for any confusion. The valves do not light up the whole thing is dead I have changed the fuse in the plug but am waiting for the 1A internal fuses to arrive as nobody in Jersey stocks them. Jersey has the same power supply as the UK and this is the same mandello with the FM issue I have had the chassis out and sprayed all the switches inside and out so there all clean I have also wise I was there cleaned the valve contacts. When I got this someone gave it to dump but instead I took it home and spent 3 weeks fixing the turntable and it's been fine for the last 5 year's it's my pride and joy and just want it to work but I don't understand fully how it works but I can solder and test parts if I need to. I hope this helps you all if you need pictures I can do that too
5th Feb 2019, 8:47 am | #20 | |
Just a note of Caution here. Why did you choose 1 amp fuses? The rear cover you pictured clearly states ''0.4A Surge Resisting'' for 240 volt mains. (0.4A = 400mA. Surge Resisting = Slow Blow = T rating = Delay Fuse by the way) Fitting the wrong current rating fuse could lead to further damage or worse a fire. Have you actually checked the original fuse has blown? Alan
