Old 27th Aug 2018, 11:20 am   #21
Default Re: Unknown battery player connection
Looking at the pictures in posts 1 and 5, I'd say the connections should be:-
Top row of tags.
2nd from right BASE. Centre lead or apex of triangle. Note potential divider and coupling capacitor.
3rd from right COLLECTOR. Note the red spot.
Bottom row of tags.
2nd from right EMITTER.
Station X is online now
Old 27th Aug 2018, 2:20 pm   #22
robert.copley1
thanks all will gie it a try bob
robert.copley1 is offline
Old 27th Aug 2018, 4:54 pm   #23
robert.copley1
ok guys I need to replace 4 capacitors for the type plessey electrolytic 50uR 12v dc wkg ce 201 max temp 70.c best replacement and where from thanks bob
ID:	168194   Click image for larger version
Old 27th Aug 2018, 5:28 pm   #24
47uF @ 25v will be ok.....Axial:
https://www.bitsbox.co.uk/index.php?...oducts_id=2375
The same outfit does radials at about 1/3rd the price of the above.
Other suppliers/prices are available.
Old 27th Aug 2018, 6:14 pm   #25
robert.copley1
thanks for that Lawrence and so cheap !
Old 28th Aug 2018, 11:08 am   #26
I agree that those Plessey caps are unreliable and should be replaced in the long run.
However that's no reason not to make sure the replacement OC71 is fitted correctly and take a few voltage readings. A battery player isn't going to kill you.
Old 28th Aug 2018, 11:31 am   #27
robert.copley1
thanks Graham will do , that's one reason I'm into the battery players , and old memories of travelling to the all nighters with my mates , one had a 60s player with it playing from lincoln to manchester in a minivan ! bob
