Old 25th Aug 2023, 4:59 pm   #1
Alrwood
Default Ferrograph 5 help
Help please
Just purchased a Ferrograph series 5 reel to reel from auction house, plugged in and it worked perfectly, decided to give a clean with switch cleaner and a quick brush, switched on again and the "Motor Starting Switch" (SW£) would not lock in position
this part , the plate and the coil,,, i think the coil acts as a magnet, does not seem to be holding in position
thanks in advance
Alrwood is offline
Old 25th Aug 2023, 5:27 pm   #2
Ted Kendall
Default Re: Ferrograph 5 help
The locking solenoid is run from the amplifier HT rail, if memory serves - start by checking if this is present.
Ted Kendall is offline
Old 25th Aug 2023, 5:37 pm   #3
Alrwood
Thanks Ted what's the best way to check that ?
Alrwood is offline
Old 25th Aug 2023, 5:55 pm   #4
ms660
ms660's Avatar
The solenoid coil is in series with the HT-ve feed from the HT secondary winding center tap and ground, the coil has the Auto Stop Switch and the Manual Stop Switch connected across it.
Lawrence.
ms660 is offline
Old 25th Aug 2023, 9:09 pm   #5
Gordondav54
You need to wait until the HT is up to full power before it will lock. If the smoothing C's are leaky the voltage might be dragged down too much. Is it hummy? If so the C's could be suspect. Also make sure the stop button end of tape foil switch is not shorted, unlikely but possible.
good luck
Gordondav54 is offline
Old 26th Aug 2023, 12:01 pm   #6
Alrwood
Sorted thanks
Alrwood is offline
Old 26th Aug 2023, 3:30 pm   #7
ms660
ms660's Avatar
Also on this model the tape speed selector and the equalizing switch should be set to the same speed, if not the hold in solenoid won't work.
Lawrence.
ms660 is offline
