18th Sep 2020, 9:32 am | #1 |
Philips F5G86A Radiogram Sound Not Reaching Speaker
Hi there,
I have a Philips F5G86A radiogram which was missing the cartridge from the tonearm. I was able to order a new cartridge (Philips GP 230) which I was told would fit and work. It's now arrived and I'm pleased to say it did fit, however I'm afraid something must be wrong as when I play a record, it's not coming through on the speaker. I can confirm the speaker does work with the radio. Also, in case useful, I believe the deck is an AG1003. One thing that I wasn't aware of however was what looks like a small crack in the tonearm (please see picture attached) - could there be something wrong with the wiring in the tonearm? If anyone knows what might be wrong I'd be very grateful to know - otherwise I would appreciate if anyone could tell me anything I could check to help me identify the problem. I've attached photos that I hope are helpful, but I can take more if needed. Thank you very much in advance, Sean |
18th Sep 2020, 9:42 am | #2 |
Re: Philips F5G86A Radiogram Sound Not Reaching Speaker
Hello and welcome to the forums.
Type "buzz test" into the Google custom search box at the top of the page.
18th Sep 2020, 12:39 pm | #3 |
Hi Graham,
Many thanks for your help. There seemed to be varying instructions for a buzz test, and I don't think I'd be able to easily access the wires inside the tone arm, however I tried the test with the pin at the end of the arm (it's a male tone arm) that goes into the female headshell. When touching the left side of this pin, there's a buzz in the speaker, but when touching the right side, there's nothing. All the best, Sean |
18th Sep 2020, 12:58 pm | #4 |
That's OK, however it does seem to indicate that your cartridge is faulty.
18th Sep 2020, 1:17 pm | #5 |
Your "Buzz" test was successful in proving that the amplifier and speakers are working. Any "new" GP230 Mono cartridge you buy now will will be nearly 60 years old and so may have failed. Suggest you advise the supplier ASAP!
Edward. |
18th Sep 2020, 11:37 pm | #6 |
This is a new 'copy' cartridge. It should be ok.
Remove the bridging link that I've arrowed. |
19th Sep 2020, 7:02 pm | #7 |
Thanks everyone for your responses.
Michael, I tried it without the bridging link, but it still doesn't work. I also spoke to the supplier, Edward, and they said it would be the first one to not work and also said I could try making a wire bridge between the two lower contacts, using copper wire. I've now tried this, but still no joy... Best, Sean |
