Old 14th Sep 2020, 10:13 pm   #1
HoraceBatchelor
Default Smoothing caps
I'm needing to replace smoothing capacitors in Philips 141u, in the schematic it states I need 50x2 mfds at 250 volts.Those exact values don't seem to be available anywhere. I've looked at all the usual places. Can someone please inform me what I can safely use that are available.
HoraceBatchelor is offline
Old 14th Sep 2020, 10:25 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Smoothing caps
47uF 400V
A pair of modern radial or axial caps should fit in the original can with room to spare.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 14th Sep 2020, 10:41 pm   #3
AdrianH
AdrianH's Avatar
I do not know the size of the capacitor, so not sure if it helps but cricklewood electronics do caps which are 50 plus 50 at 500 volts in a 35mm dia can for around £8.30 plus delivery and Vat.
Other than that is there not a supply through the BVWS, or as Graham has said restuff the big can with modern caps.
Adrian
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is offline
Old 14th Sep 2020, 10:57 pm   #4
Nuvistor
Nuvistor's Avatar
Link for capacitor in post #2
https://www.cricklewoodelectronics.c...Capacitor.html
Posiible capacitors for re stuffing the original can.
https://www.cricklewoodelectronics.com/47H450.html
Frank
Nuvistor is offline
Old 15th Sep 2020, 12:27 am   #5
HoraceBatchelor
Thanks a lot for the suggestion. I am stuffing the original can, so luckily the cheaper option suits me fine. I was about to order these but just wanted reassurance i was doing right with them being of different value. Thanks, much obliged.
Peter.
