Reply
Old 21st Sep 2023, 4:26 pm   #1
Jono400
Default Kenwood TS711e audio issue?
Guys any ideas … Newly purchased Kenwood ts711e, can’t seem to get any audio from it, occasionally if I press the attenuator button and then the ch.q button I can get about 30 seconds off rf hiss before it just cuts off. If I press the attenuator button whilst there is audio it normally cuts the audio of as well. This is all on ssb can’t get anything on FM mode. Sure I have everything set fine ie. squelch setting and rf gain .
Any ideas ? Anyone based uk able to help me out with reasonable priced repairs ? Unfortunately suffering health issues.. cancer just now and not able to work .
Jono400 is offline   Reply With Quote
Old 23rd Sep 2023, 5:26 pm   #2
Jono400
Default Re: TS711e audio issue ?
Also noticed occasionally the radio upon switch on will produce rf noise but after so long just cuts out.
Old 24th Sep 2023, 5:31 pm   #3
HamishBoxer
HamishBoxer's Avatar
Worth talking to Kent Rigs, seem to get very good ratings.
HamishBoxer is offline   Reply With Quote
Old 24th Sep 2023, 9:15 pm   #4
Jono400
Default Re: Kenwood TS711e audio issue?
Okay thanks appreciate that. Found earlier tonight that when the problem arose ie. the majority of the time ! that pressing ptt of the mic in FM mode kicked the RF noise into life only to cut out again shortly afterwards ! Thought a sticky relay could have been the issue but unfortunately the ptt method of getting the rx is not working when tried tonight .
Reply
